Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
rear strut tower brace legal?
Old May 19, 2003 | 02:26 PM
Bills01ITR445's Avatar
Default rear strut tower brace legal?
legal for stock autoX classes? I'm going from STX to D stock, going to remove CAI
Old May 19, 2003 | 02:43 PM
RineRacing's Avatar
Default Re: rear strut tower brace legal? (Billz01ITR445)
STX - Yes
D Stock - No
Old May 19, 2003 | 06:05 PM
Default Re: rear strut tower brace legal? (Geratol)
not even the JDM ITR rear bar?, its stock in Japan
Old May 19, 2003 | 06:07 PM
Lo-Buck EF's Avatar
not even the JDM ITR rear bar. even if its stock in Japan. this aint japan pal
Old May 19, 2003 | 06:24 PM
Default Re: rear strut tower brace legal? (SOLOef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOLOef &raquo;</TD></TR><TR><TD CLASS="quote"> this aint japan pal </TD></TR></TABLE>I knew somebody would say that, hehe what about ground control coilovers? Adjustable spring perches are allowed, but the spring load-bearing surface must be in the same location relative to the shock mounting points as on the standard part. I am assuming this means they are ok since they dont change geometry/ mounting points?
Old May 19, 2003 | 06:31 PM
.RJ's Avatar
.RJ
follow the link in the FAQ for scca classing
Old May 20, 2003 | 04:38 AM
markw's Avatar
Coilovers take you out of stock class. Change the springs and you're out of stock. You can run replacement shocks, and that's about it. Stock is Stock. Sounds like an STS ride to me.
Old May 20, 2003 | 05:03 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
What part of the Stock classification do you have confusion over?
Did the car come with these parts as sold in the US?
If so, yes.
If not no. It's stock fer christ sake.
Shocks and tires are about all you can mess with. (front sway bar also, though that helps FWD cars nadda.)
Old May 20, 2003 | 05:56 AM
PupaScoopa's Avatar
Default Re: rear strut tower brace legal? (madhatter)
...and you can do brake pads in stock. As well as a "drop in" filter.
Old May 20, 2003 | 11:32 AM
vwong's Avatar
Default Re: rear strut tower brace legal? (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa &raquo;</TD></TR><TR><TD CLASS="quote">...and you can do brake pads in stock. As well as a "drop in" filter.</TD></TR></TABLE>
And exhaust is legal in Stock classes.
Old May 20, 2003 | 11:33 AM
.RJ's Avatar
.RJ
Default Re: rear strut tower brace legal? (vwong)
and front sway bar, and plugs/wires, and alignment and light weight wheels and so forth and so forth.
get a rulebook...
MansuDC2
Aug 1, 2005 06:06 PM
PY 01-0972
Apr 30, 2005 10:38 PM
Duck Sauce
May 7, 2002 02:40 PM
RC211V
Apr 5, 2002 02:14 AM
