analyze my times plz! D16z w/greddy
Old May 19, 2003 | 02:18 PM
hondafrk's Avatar
Default analyze my times plz! D16z w/greddy
hey guys, On friday it was my first time at the track for the year and I only ran once.
I have a 92 hatchie with a d16z6, dx tranny, greddy sohc turbo kit, greddy FMIC.
I was running really crappy street tires at 22psi, running 6psi boost and I had some mad wheel hop all the way thru 1st gear.
RT: .532
60ft: 2.223
1/4: 14.41
mph: 95.56
I was hoping to dip low into the 14s or maybe high 13s what gives?
I dont really have alot of experience at the track but last year I was running 15.64 on my stock z6 without the turbo.
What are you guys with sohc turbos running.
Can anybody give me some good advice?
Thanks,
Jesse
Old May 19, 2003 | 02:35 PM
DaveF's Avatar
need to work on the 60f's than youll dip to the 13's....2.0 60fts on street tires, like the stock pos ones that come with honda's
also an si trans would help too
Old May 19, 2003 | 06:01 PM
nsxmatt's Avatar
Default Re: (2.2Lcivic)
2.2 60ft is very decent on street tires. Si tranny would help your time though and maybe some mount inserts to calm the wheelhop.
Old May 19, 2003 | 06:54 PM
boostsohfast's Avatar
Default Re: (nsxmatt)
i don't think 95 mph will get you into the 13's. you should try to lose that dx tranny because the gears are too long with only 6 psi on a greddy turbo. did you have the dx tranny when you ran all motor?
Old May 19, 2003 | 09:24 PM
10seconds's Avatar
Honda-Tech User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">need to work on the 60f's than youll dip to the 13's....2.0 60fts on street tires, like the stock pos ones that come with honda's
also an si trans would help too</TD></TR></TABLE>
2.0 on street tires...............your carzy.....unless you mean Drag Radials...cause they are still a street tire
steve
Old May 19, 2003 | 09:26 PM
10seconds's Avatar
Honda-Tech User
Default Re: analyze my times plz! D16z w/greddy (hondafrk)
si tranny, 12 psi for boost, slicks.....i think you will pull off some low 13's....maybe
steve
Old May 19, 2003 | 10:47 PM
norcalcrx's Avatar
Default Re: analyze my times plz! D16z w/greddy (10seconds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10seconds &raquo;</TD></TR><TR><TD CLASS="quote">si tranny, 12 psi for boost, slicks.....i think you will pull off some low 13's....maybe
steve</TD></TR></TABLE>
good tuning and 9psi, si tranny and slicks will get him low 13's
see my sig
Old May 19, 2003 | 10:49 PM
Broken Gearbox's Avatar
yea lose the DX tranny and go find a EX/Si tranny...i dont think 6psi is enough too run 13s..so next time turn up the boost maybe around 8-10?
Old May 20, 2003 | 11:00 AM
hondafrk's Avatar
Default Re: analyze my times plz! D16z w/greddy (Powered By D15)
how much boost can a stock z6 handle?
what kind of slicks do you guys recommend
Old May 20, 2003 | 12:40 PM
10seconds's Avatar
Honda-Tech User
change the head gasket and tune it...and i myself would run 10-12 all day...just to be safe though
quicksol95
Aug 28, 2004 08:56 PM
Slvr_CRX
Aug 22, 2003 06:52 PM
boostin4drcivic
Nov 7, 2002 12:23 PM
BigD+Itsuki
Aug 29, 2002 07:46 AM
SilverS
Nov 6, 2001 08:45 PM
