rattling noise at 3-3.5K RPM
Old May 19, 2003 | 01:48 PM
B18C1 '96 Coupe's Avatar
Default rattling noise at 3-3.5K RPM
I have a certain noise its a rattling noise from the front drivers tire. Anyone have a suggestions. I thought the brake sheild so i checked that and moved it so thats not it. Any other ideas?
Old May 19, 2003 | 02:04 PM
Mikey's Avatar
Default Re: rattling noise at 3-3.5K RPM (B18C1 '96 Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1 '96 Coupe &raquo;</TD></TR><TR><TD CLASS="quote">I have a certain noise its a rattling noise from the front drivers tire. Anyone have a suggestions. I thought the brake sheild so i checked that and moved it so thats not it. Any other ideas?</TD></TR></TABLE>
I don't know what a "brake shield" is but judging by your username I'm assuming you have a GSR motor in your Civic. The 94+ Integra GSR exhaust manifold is infamous for breaking inside the A pipe, thus causing a rattling between 3 and 4 grand.
Mine occurs at 3400.
Old May 19, 2003 | 02:10 PM
Default Re: rattling noise at 3-3.5K RPM (Mikey)
That might be it. I only have the rear part of the sheild on. man I need a header for it but I dont really care I hope to be going SOHC style in a minute
Old May 19, 2003 | 02:15 PM
delslow94's Avatar
i have that same thing on my b16a3 del sol. i have a header and exhaust and im assuming it might be the cat that has broken apart. i checked all the fittings for everything but its still there. try checking your cat for stuff to break. i know carsounds are infamous for that happening.
Old May 19, 2003 | 02:17 PM
EGsixer's Avatar
Default Re: rattling noise at 3-3.5K RPM (delslow94)
and yes i have the same problem...it sounds like its in the cat. but i know its not. cause my cat is hollowed out....its been annoying me and ive tooken it to so many muffler shops and they cant do **** about it either.
Old May 19, 2003 | 02:55 PM
built562's Avatar
Default Re: rattling noise at 3-3.5K RPM (EGsixer)
i have a b16 in a 95 civic and my car makes a vibrating noise at exactly 3000 rpm and it turns out to be my motor mounts,
Old May 19, 2003 | 02:59 PM
Mikey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGsixer &raquo;</TD></TR><TR><TD CLASS="quote">and yes i have the same problem...it sounds like its in the cat. but i know its not. cause my cat is hollowed out....its been annoying me and ive tooken it to so many muffler shops and they cant do **** about it either. </TD></TR></TABLE>
Like I said before, if you have narrowed down that the heat shields are not the source of the rattling, it's generally the OEM exhaust manifold A pipe that needs to be replaced. It's even an Technical Service Bulliten (TSB) on http://www.alldata.com.
Old May 24, 2003 | 04:24 PM
EGsixer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey &raquo;</TD></TR><TR><TD CLASS="quote">
yea i wish it was the OEM exhaust manifold..but im not runnin the oem one..so i dont think its that..also i have checked all my heatshields and even removed some. still no luck .
Old May 24, 2003 | 05:45 PM
eg_nezay's Avatar
I had that problem before and it ended up being a washer. The bolt was loose causing the washer to move freely and make a rattle noise.
Try looking for any loose bolts, around where the area occurs.
Old May 25, 2003 | 01:06 AM
BoostedSixthGen's Avatar
Default Re: rattling noise at 3-3.5K RPM (eg_nezay)
i have the exact same problem w/my car too. I have a 99 ek w/a jdm gsr in it and it makes that rattling noise at about 3k. i cant figure it out and it bugs the **** outta me.
Old May 25, 2003 | 12:19 PM
binkster's Avatar
Default Re: rattling noise at 3-3.5K RPM (MugenGSRX)
Its the cat hitting the heat shield. I have the same noise at the same RPM range. I put my car on a lift and while my friend was giving it gas I stuck a sock between the cat and the heat shield and the noise dissapeard. Seeing how a sock can be somewhat flamable, i took it out and the noise cam back.
Old May 25, 2003 | 12:35 PM
I wanna be Steve!'s Avatar
Default Re: rattling noise at 3-3.5K RPM (binkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by binkster &raquo;</TD></TR><TR><TD CLASS="quote">I stuck a sock between the cat and the heat shield and the noise dissapeard. Seeing how a sock can be somewhat flamable, i took it out and the noise came back.</TD></TR></TABLE>
hehehe..
Old May 26, 2003 | 04:08 PM
jdmgsrcoupe's Avatar
Default Re: rattling noise at 3-3.5K RPM (I wanna be Steve!)
O.K. Here's the deal. I too have a GSR motor in a 97 coupe. Tonight after work I had a brain fart. I drilled a hole in both downpipes on my manifold. I then welded them up, welding the inner pipe to the outside of the manifold. Boom..........rattle gone. Just a thought, since now it is a proven fact that it is the down pipe of the manifold. Hope this helps!!!! L8er!!!
Old May 26, 2003 | 05:53 PM
JustinL's Avatar
would the sound go away when the clutch is pressed? mine rattles and idle and about 3-3500 it rattles and grinds. btw mines a y7
jns5209
Honda Civic (2006 - 2015)
Sep 8, 2017 03:49 AM
mike001
Nov 20, 2005 06:50 AM
erikiksaz1
Sep 13, 2004 06:00 PM
