are ebay strut bars and nuespeed different?
Old May 19, 2003 | 01:45 PM
DR.DRum
Guest
Posts: n/a
Default are ebay strut bars and nuespeed different?
i dont know anything on suspension. i get different things from everyone, some say some are different, some say no difference. whats the truth here?
Old May 19, 2003 | 02:13 PM
Xlerate9's Avatar
Default Re: are ebay strut bars and nuespeed different? (DR.DRum)
yes they are different. Ebay strut bars are cheap and weak. The neuspeed bar is very rigid and all 1 peice so that makes it even stronger. Save the money and buy the neuspeed bar... you can find them for $75 used and <$100 new.
Old May 19, 2003 | 02:22 PM
optikal_blitz's Avatar
typeS are real good too.
Old May 19, 2003 | 03:29 PM
DR.DRum
Guest
Posts: n/a
Default Re: (NatakuBlitz)
so is the strut bar on top and bottom in the front?
whats sway bar??
ive herd theres 3 bars, not sure what is what
thanks
Old May 19, 2003 | 03:33 PM
aklucsarits's Avatar
New User
Effectively the same thing. Unless you care about the way it looks, just get a cheapo ebay one. I promise you that you would not be able to tell the difference between a $25 ebay strut tower bar and a $100 Neuspeed or whatever bar...
Andrew
Old May 19, 2003 | 07:22 PM
kotetu's Avatar
Default Re: are ebay strut bars and nuespeed different? (aklucsarits)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aklucsarits &raquo;</TD></TR><TR><TD CLASS="quote">Effectively the same thing. Unless you care about the way it looks, just get a cheapo ebay one. I promise you that you would not be able to tell the difference between a $25 ebay strut tower bar and a $100 Neuspeed or whatever bar...
Andrew</TD></TR></TABLE>
Andrew, I've heard you can flex the ebay cheapos with your hand. With my neuspeed, I could stand on it and it will remain rigid.
That seems a LOT better to me.
Old May 19, 2003 | 08:29 PM
del_parker's Avatar
Default Re: are ebay strut bars and nuespeed different? (kotetu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kotetu &raquo;</TD></TR><TR><TD CLASS="quote">
That seems a LOT better to me. </TD></TR></TABLE>
i can't flex my el cheapo ebay one...err, two actually-front and rear.
Old May 19, 2003 | 08:30 PM
kotetu's Avatar
Default Re: are ebay strut bars and nuespeed different? (del_parker)
Did they come with any brand name?
Old May 19, 2003 | 08:32 PM
del_parker's Avatar
nope. i did replace the nuts/bolts on them though. the ones that came with the bar are crap.
Old May 19, 2003 | 08:42 PM
sslude's Avatar
where do you get neuspeed strut bars for 100 new?
Old May 19, 2003 | 09:23 PM
Ludespeed13's Avatar
I'd like to know too.
Old May 19, 2003 | 09:38 PM
SpeedGyrl's Avatar
Default Re: are ebay strut bars and nuespeed different? (sslude)
I was wondering the same thing myself
Old May 19, 2003 | 09:46 PM
The Rob's Avatar
Go with the Ebay strut tower bars.
Unless you are going with a 3 (or more) point strut tower brace you won't feel a large difference with any brand strut tower brace.
The money you save from going Ebay is better spent on swaybars, shocks, springs, etc.
-Rob-
Old May 19, 2003 | 11:01 PM
typeRSXS's Avatar
get neuspeed... works better then ebay ones...
Old May 20, 2003 | 07:18 AM
New User
Standing on a strut tower bar is a meaningless test. It does not see loading from the top or bottom. It would only see loading from the sides.
Andrew
Old May 20, 2003 | 07:22 AM
ludesleep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker &raquo;</TD></TR><TR><TD CLASS="quote">
i can't flex my el cheapo ebay one...err, two actually-front and rear. </TD></TR></TABLE> and i can flex my friends DC. All you have to do is adjust the tension bolts on the sides and they wont flex.
Old May 20, 2003 | 07:24 AM
COMplex.'s Avatar
Default Re: are ebay strut bars and nuespeed different? (ludesleep)
i have neuspeed upper front, upper rear, and lower rear.
thing is rigid as hell
i wouldn't trust the no name ebay items.
Clint in KY
Mar 21, 2010 06:51 AM
teddy_dc2
Suspension & Brakes
May 7, 2006 10:01 PM
onnoff7
Feb 16, 2006 08:26 PM
Tangy2001
Jan 29, 2006 12:13 PM
VTEC-DA
19
May 20, 2003 07:17 AM
