Nasty Grinding noise, even when my car isn't in gear, any ideas???
Old May 19, 2003 | 01:30 PM
BottomOutKid's Avatar
Default Nasty Grinding noise, even when my car isn't in gear, any ideas???
Sup. I got a camber kit installed recently and ever since then when I start my car, there is a grinding noise that is very intermittent and not consistent at all. It happens at any time whether the car is in gear or not. On start-up, it chimes in a little, but usually doesn't happen when I'm at a light. Do you guys have any idea what it could be? It sounds like a metal spinning disc on a pole that isn't bolted down all the way and his hitting stuff around it. Thats the only analogy I can think of. Any ideas you have would be great.
Old May 19, 2003 | 01:31 PM
Oh yeah sorry, some other stuff. It doesn't seem like it has anything to do with the camber kit being installed because its coming from the engine bay area. Just lettin you know when it started happeninig
Old May 19, 2003 | 01:37 PM
WiggiE's Avatar
New User
Default Re: (BottomOutKid)
Does it happen all the time or only when the car is moving?
Old May 19, 2003 | 01:59 PM
The only time I can recall it happening is when I start the car up for the first time for the day. It doesn't really happy at red lights so its mostly when its moving, and in low gears.
Old May 19, 2003 | 03:01 PM
WiggiE's Avatar
New User
Check to see if the camber kit is rubbing on something. If the noise started after you got it installed, it could very well be it.
If a shop installed it for you take it back to them. If you did it yourself check all around that area.
XaznKewLguyX
Jul 7, 2006 04:39 PM
Stein
Aug 16, 2004 07:48 PM
d16why
18
Oct 5, 2003 09:26 AM
SubieDude
Mar 18, 2003 08:31 AM
thickfacek
Feb 9, 2003 09:08 AM
