94 accord tranny fluid drain...
Old May 19, 2003 | 11:36 AM
Mike813's Avatar
Default 94 accord tranny fluid drain...
Anyone know where the drain bolt is located??
off a 94 accord auto...
and how much trouble would it be to get to it??
never messed with the tranny before, so i need step by step guide :\
thanks.
Old May 19, 2003 | 12:39 PM
FULLTHROTTLE's Avatar
Default Re: 94 accord tranny fluid drain... (Mike813)
Under the passenger side of the engine you will see a bolt that is round on the outer edge and has a 3/8 inch square hole in teh middle. Remove this bolt (over a drain pan) and drain the transmission fluid. The car should be warmed up and on a level surface for best results. When the fluid is done draining clean the material from the magnet on the drain bolt and reinstall. Torque to 33 if you have a torque wrench. Put approx 2.5 qts trans fluid in the dipstick hole and start car and let it warm up. Go through the gears and reverse and shut off car and check fluid level within 30 seconds on the dipstick. Add if needed. Youre all done. time for a
Joser_8051218
Transmission & Drivetrain
May 19, 2014 01:50 PM
portugueboy10
Apr 4, 2011 01:40 PM
Kyles ej1
Sep 23, 2004 04:41 PM
2lobes1engine
26
Jun 29, 2004 08:27 PM
hagrid
Dec 13, 2002 10:41 PM
