Need two cigarette lighters.
How would i go about wiring two cigarette lighters into my car. I plan on getting a pivot shift light, so i want a second cigarette lighter that i can put behind or on the side of the center console area. Or is there a way to rewire the shift light?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse »</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
uhh pep boys?
and what purpose would it be to have it behind the center consol?
uhh pep boys?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse »</TD></TR><TR><TD CLASS="quote">Where are the 12v switches? Im sorry i dont know anything about this stuff</TD></TR></TABLE>
HAHA
12v switched means 12 volts of switched power. Meaning it's turned on and off by the ignition. If you are lost already I'd suggest something like this:
HAHA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrillhouse »</TD></TR><TR><TD CLASS="quote">How would i go about wiring two cigarette lighters into my car.?</TD></TR></TABLE>
ya know for a minute I thought you were a serious smoker
i used to have shiftlight wired up correctly (i thought it was)... until my shiftlight got stolen
the problem is, he doesn't know where there are other sources of 12v in his car.
thanks to team-integra.net... this will SURELY help you out:
Here is a spot to grab Constant Power, Accesory Power, or Parking Light power in your 94-97 Integra. The image is looking at the fusebox under the steering column
Here is a spot to grab Constant Power, Accesory Power, or Parking Light power in your 98-01 Integra. The image is looking at the fusebox under the steering column
Explanations:
• Constant Power: Always shows 12v regardless of Key position
• Ignition: Shows 12v with key only in the "ON" position
• Flashing Lights: Shows 12v with parking lights on
• Accesory: Shows 12v with key in "ACC" or "ON"
To connect to one of these slots, use a .250" inch female spade connector
if you still havent figured it out... if you want your shift light to work well. my recommendation is to hack away at the cigarette connectors and find the positive end and connect it to the mentioned .250" inch female spade connector and connect the other end to the IGNITION slot. connect the negative end of the wire to a negative source. i recommend finding a spot in your car that is metal and connected your car's chassy...a bolt perhaps (when i had my shiftlight, i located the deadpedal bolt and it worked great)? well good luck!
NRG
.the problem is, he doesn't know where there are other sources of 12v in his car.
Explanations:
NRG
jaxx4k
Jun 5, 2005 11:29 PM
