OBD1 injectors
Old May 19, 2003 | 09:28 AM
Timmah!!'s Avatar
Default OBD1 injectors
If I were to use the injectors that came with my JDM D15b, what wires would I solder together. The 4 red ones and the other wire in that connector going to the resistor box?
My old injectors have some 300k miles on them and are in verry bad shape.
I know there was a thread a while back but I cant find it.
Any puctures would be awesome.
Old May 19, 2003 | 04:37 PM
Timmah!!'s Avatar
Default Re: OBD1 injectors (azroth)
can anyone help me with this. I dont want to start cutting wires and hopeing it will work.
Old May 19, 2003 | 05:33 PM
zCivic's Avatar
theres 5 wires in the resistor box....just connect all 5 together....unsure about the colors
Old May 19, 2003 | 05:51 PM
Timmah!!'s Avatar
Default Re: OBD1 injectors (zCivic)
I just cut them right befor the green clip of the resistor box and solder the five of them together right. Good thats what i thought. I know i am going to have to change the injector clips for the new injectors. Does anyone know if they are higher flowing injectors or not? I dont think they are but I may be wrong.
Old May 19, 2003 | 05:57 PM
USDM 4G VTEC's Avatar
OBD1 injectors will fry up in a OBDO car......
ihave heard that u have to remove the inj resistor off in order to use them
but i havent personally taken the inj resistor off... but i know fo sure than a OBD1 inj will die on a OBDO car...
Old May 19, 2003 | 06:15 PM
Timmah!!'s Avatar
Default Re: OBD1 injectors (USDM 4G VTEC)
I know that they will fry if you do not remove the resistor box. But I have seen threads that spooke of removing the resistor box, solderg the wires together, and using the OBD1 injectors.
Old May 20, 2003 | 05:12 PM
vtecrx's Avatar
you can remove the resistor box and run OBD1 or 2 injectors in an OBD0 car. YOu simply solder the wires together that used to go to the resistor together and match the solid color injector wires together and solder the blk/red wires to the yel/blk wires
Old May 20, 2003 | 07:42 PM
Timmah!!'s Avatar
Default Re: OBD1 injectors (vtecrx)
So there is more to it then just soldering the 5 wires that go to the resistor box together?
Old May 20, 2003 | 07:47 PM
spun Vtec's Avatar
not really just soldering the 5 wires together should do the trick or you could use the 7 wire capped plug (connects them all together) on your obd1 harness then all you would have to do is splice the solid color injector wires together red to red ltblue to ltblue brown to brown exc.. but if all 5 wires from the resistor box are soldered together it will still work but kinda rigged.
larry
im spunvtec on aim if you have any questions
RICE POLICE SIP
Feb 13, 2010 10:01 AM
LSV_REX
May 28, 2008 06:41 AM
drSquish
Jan 19, 2006 01:54 PM
e jay one
Aug 6, 2005 02:48 PM
