auto to manual
Ok guys,
I am about to do my auto to manual swap. I know I need:
Axles
ECU
Clutch hydrolic lines, slave cylinder
engine/tranny/clutch/flywheel
clutch pedal unit
brake/gas pedal unit
Shifter, shift linkage
starter
tranny mounts
I am pretty sure I covered everything there see anything missing? Also can any one that has done this before, as in not heard from someone, tell me a little about the wiring involved? I am a little shakey on that. I think the interlock system will go into the clutch pedal switches correct? Then I just need to connect some of the wires from the auto shifter into where the TCM is? sound right?
Thanks,
Josh
Modified by skrewdlude at 8:29 PM 5/19/2003
Axles
ECU
clutch pedal unit
starter
tranny mounts
Thanks,
Josh
Which year prelude?
if it's a 5th gen.. you'll also need:
1)you dont need the axles. SS axles will fit just fine.
2)you need one of the tranny mount from a 5speed prelude
3)you also need the 5spd starter
Man
Man
getupoffthatthan
10
Jul 27, 2007 11:11 PM
Sc00teR_92h23
Jun 23, 2004 05:26 AM
putting my old JDM h22 in it.
