FS: 1998 Integra Type R #370...
Old May 19, 2003 | 09:04 AM
b18c1eg
Guest
Posts: n/a
Default FS: 1998 Integra Type R #370...
I am selling my 1998 Integra Type R. It has 87,xxx miles on it. It isn't perfect by no means, nor will I pretend it is. The interior is in good shape except the front seats are stained, and the tops of the rears are sun faded. The front driver side fender has a dent in it, and there are some door dings on the rest of the car. The engine bay is extremely clean, and runs great. I did a compression test on it a few weeks back and it read 195 across the board. It does burn some oil when you drive it hard, so since the compression test checked good, the oil rings must be the culprit.
Here is a list of the following items I have done to it all within the last couple months.
adjusted the valves
timing belt
water pump
STR cam seal
valve cover seal kit
plugs
MSD wires
cap
rotor
fuel filter
breather chamber
PCV valve
Bridgestone S-03's
Cusco Zero-2 sus kit w/ pillowball mounts
Cusco rear upper carbon fiber brace
Cusco front lower tie bar
Cusco brake cylinder stopper (LHD version... only one in the USA at this time)
JDM Type R oil cap
All the normal PM items have been taken care of. This would be a great start for someone. I've been contemplating CTR pistons and rings... but then it always snowballs into having the motor fully built with TODA C cams, etc... and my thoughts get out of hand and budget. I can provide pics via email, since I do not have a picture host.
VIN # JH4DC2312WS002630
Price: $12,500obo
Thanks,
Brad
brad.himes@napsusa.com
Old May 19, 2003 | 10:17 AM
Drow's Avatar
does it carry a salvage title ?
Old May 19, 2003 | 10:34 AM
b18c1eg
Guest
Posts: n/a
Default Re: (Drow)
It has a clean title. In fact... here is the Carfax report from Jan. when I bought it.
GOOD NEWS! CARFAX search results confirm this 1998 ACURA INTEGRA TYPE-R (JH4DC2312WS002630) qualifies for the FREE $5,000 CARFAX Clean Title History Guarantee. By ordering this CARFAX Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
SECTION: SECTION RESULTS:
Vehicle Specifications JH4DC2312WS002630
Title Check Clean Title History Guaranteed
Odometer Rollback Check No Odometer Rollback Detected
Problem Check No Problems Found
Registration Check Checked 7 types of vehicle registration
Vehicle History Details 6 Total Vehicle History Records Found
How safe and reliable is a 1998 ACURA INTEGRA TYPE-R?
Get a CARFAX Safety & Reliability Report for every Vehicle History Report you run!
Upgrade your account Now!
NOTE: This vehicle has not been inspected by CARFAX and it may have problems that have not been reported to CARFAX. CARFAX recommends a vehicle inspection by a professional mechanic.
How did CARFAX analyze this vehicle's history?
VIN: JH4DC2312WS002630
Year/Make/Model: 1998 ACURA INTEGRA TYPE-R
Body Style: HATCHBACK 2 DR
Engine: 1.8L L4 PFI DOHC VTEC
Fuel: GASOLINE
Driveline: FRONT WHEEL DRIVE
Carburetion: FUEL INJECTED
Cylinders: 4
Manufactured in: JAPAN
GOOD NEWS! CARFAX search results confirm this 1998 ACURA INTEGRA TYPE-R (JH4DC2312WS002630) qualifies for the CARFAX FREE $5,000 Clean Title History Guarantee.
CARFAX analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
Problem Titles Checked: Results:
Salvage/Junk Checked - No Salvage/Junk Title Found
Rebuilt/Reconstructed Checked - No Rebuilt/Reconstructed Title Found
Flood Damage Checked - No Flood Damage Title Found
Damage Disclosure Checked - No Damage Disclosure Found
Manufacturer Buyback (LEMON) Checked - No Manufacturer Buyback Found
Exceeds Mechanical Limits (EML) Checked - No EML Found
Not Actual Mileage (NAM) Checked - No NAM Found
NOTE: Click here for a complete CARFAX Glossary.
GOOD NEWS! CARFAX search results on this 1998 ACURA INTEGRA TYPE-R (JH4DC2312WS002630) did not uncover a potential odometer rollback. CARFAX analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
Date Reported: Odometer Reading:
03/15/2000 27,532
01/30/2001 54,230
05/10/2002 78,939
GOOD NEWS! CARFAX search results on this 1998 ACURA INTEGRA TYPE-R (JH4DC2312WS002630) did not uncover any of the following problems:
Problems Checked: Results:
Accident Checked - No Accident Record Found
Salvage Auction Checked - No Salvage Auction Record Found
Failed Emissions Inspection Checked - No Failed Emissions Record Found
Fire Damage Checked - No Fire Damage Record Found
Crash Test Vehicle Checked - No Crash Test Vehicle Record Found
Grey Market Vehicle Checked - No Grey Market Vehicle Record Found
CARFAX search results on this 1998 ACURA INTEGRA TYPE-R (JH4DC2312WS002630) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Registrations Checked: Results:
Lease Checked - No Lease Registration Found
Rental Checked - No Rental Registration Found
Government Checked - No Government Registration Found
Taxi Checked - No Taxi Registration Found
Fleet Checked - No Fleet Registration Found
Commercial Checked - No Commercial Registration Found
Non-Profit Checked - No Non-Profit Registration Found
With the new CARFAX Test Drive ReviewTM, you can share your experience with this vehicle right on the CARFAX Vehicle History Report. Add to this vehicle's history here!
The CARFAX database contains a total of 6 vehicle history records on this 1998 ACURA INTEGRA TYPE-R (JH4DC2312WS002630):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
05/02/1998 Georgia
Motor Vehicle Dept.
Peachtree City, GA
Registered as
private vehicle
06/09/1998 Georgia
Motor Vehicle Dept.
Peachtree City, GA
Title #34784127
Title or registration issued
First owner reported
03/15/2000 27,532 Georgia
Inspection Station
Passed emissions inspection
01/30/2001 54,230 Georgia
Inspection Station
05/10/2002 Georgia
Inspection Station
05/10/2002 78,939 Georgia
Motor Vehicle Dept.
Newnan, GA
Title #775254021305027
Title issued
Registration issued
Ownership transfer reported
01/20/2003 Consumer resource provided by:
Edmunds.com Manufacturer-Recommended Maintenance Schedules
Check this vehicle's service schedules, estimated costs and recall notices at Edmunds.com.
Old May 19, 2003 | 11:01 AM
Del's Avatar
Del
Default Re: (b18c1eg)
might be down for a trade.. check the sig.
Old May 19, 2003 | 12:22 PM
b18c1eg
Guest
Posts: n/a
Default Re: (Del)
Sorry, the only trading I will consider is for an EK, something AWD, or something RWD.
BTW... your Del Sol looks really nice.
Thanks,
Brad
Old May 19, 2003 | 03:11 PM
navin's Avatar
no love for hybrid EG's..
Old May 19, 2003 | 04:26 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: (navin)
so are you in georgia or what, if you havent sold it in 2 weeks, i may be interested, can you email a some pics of the "messed" up parts to me at fast_ass_honda_crx@yahho.com
Old May 19, 2003 | 04:38 PM
FRANK_WHITE's Avatar
do you have any pics of the car? if so please send them to frankwhiteson@aol.com
Old May 19, 2003 | 05:35 PM
GSxRated's Avatar
Default Re:
AWD? How about an Audi A4 1.8T Quattro Manual Blue with Cream Leather, Bose sound system, Moonroof, new transmission.
Old May 19, 2003 | 08:43 PM
b18c1eg
Guest
Posts: n/a
Default Re: Re: (GSxRated)
Must be Japanese.
Old May 19, 2003 | 08:46 PM
b18c1eg
Guest
Posts: n/a
Default Re: ................(Y49CRXSIZC)
I live in Mattoon, Illinois.
Old May 19, 2003 | 08:48 PM
b18c1eg
Guest
Posts: n/a
Default Re: ................(Y49CRXSIZC) (b18c1eg)
Everyone has mail...
Old May 20, 2003 | 07:29 PM
b18c1eg
Guest
Posts: n/a
I will be willing to remove some of the parts to drop the price a bit.
Thanks,
Brad
Old May 20, 2003 | 08:12 PM
BryanSprinkel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1eg &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, the only trading I will consider is for something AWD, or something RWD.
How about 4wd? click me for a pic *worth a shot*
Any pics?
Old May 20, 2003 | 08:23 PM
GeorgeJetson's Avatar
Default Re: (BryanSprinkel)
ill give you a 2000 civic si and some cash?
Old May 20, 2003 | 09:22 PM
b18c1eg
Guest
Posts: n/a
Default Re: (georgejetson)
I'm really just wanting the money at this point. I have my sights set on something else. How've you been? I haven't talked to ya for awhile.
Thanks,
Brad
Old May 22, 2003 | 12:54 PM
b18c1eg
Guest
Posts: n/a
Bump it up.
Old May 23, 2003 | 08:33 AM
555R's Avatar
Default Re: FS: 1998 Integra Type R #370... (b18c1eg)
send pics to
blacksunracing@comcast.net
let me know details too
Old May 23, 2003 | 08:45 AM
b18c1eg
Guest
Posts: n/a
Default Re: FS: 1998 Integra Type R #370... (555R)
You have mail.
Old May 23, 2003 | 12:09 PM
JiggyKooAndy's Avatar
send pics to jiggykooandy@hotmail.com please
thanks,
andy
P.S. i'm in the burbs of chicago, so i might take a trip down to check it out if i like it.
Old May 23, 2003 | 04:16 PM
b18c1eg
Guest
Posts: n/a
Default Re: (JiggyKooAndy)
I finally got someone to host the pics...
http://www.imagestation.com/album/?id=4290094559
Let me know if you have any questions.
Thanks,
Brad
Old May 24, 2003 | 09:01 AM
Jamison182's Avatar
hit me up some pics at oddball327@aol.com ... how close from chicago are you, and is it north, south... etc etc... thanks
Old May 24, 2003 | 09:02 AM
jjdm327's Avatar
Default Re: (Jamison182)
edit: im oddball327@aol.com, sorry, i was logged on my buddies name, and didnt know it....
Old May 24, 2003 | 08:10 PM
H22aInside's Avatar
Default Re: (jjdm327)
lol, my name is brad too and im looking for a ITR. i am very intrested in the car and was wondering if it would be a problem to ship it down to houston texas. i have always wanted a itr and this looks like my perfect oppourtunity.
my e-mail is ecir_tog@yahoo.com plz e-mail me if ur still selling the car, my aim is hybridaccordpwr, hit nme up on AIM if u catch me online.
like i said i really want a ITR, thx in advance Brad
Old May 25, 2003 | 11:27 AM
b18c1eg
Guest
Posts: n/a
I'm about 3 hours south of Chicago on I57. Let me know if you are interested.
Thanks,
Brad
