Pulling the head, what should I replace?
Old May 19, 2003 | 08:59 AM
B2FiNiTY's Avatar
Default Pulling the head, what should I replace?
What should I replace when pulling the head?
Head studs? Should I go with ARP?
Any gaskets? Etc. Thanks.
Old May 19, 2003 | 09:14 AM
.RJ's Avatar
.RJ
Default Re: Pulling the head, what should I replace? (B2FiNiTY)
everything. head bolts, all the gaskets. because the one you dont buy is the one that will need to be replaced, so just buy everything.
B2FiNiTY's Avatar
Default Re: Pulling the head, what should I replace? (.RJ)
Which gaskets?
1)Valve cover gasket
Old May 19, 2003 | 09:23 AM
.RJ's Avatar
.RJ
the plug hole gaskets
Manifold Gaskets
TB gasket
headgasket
headbolts
I also replaced the ex manifold studs and PCV tube (B18A1 has an oil separator box) at the same time.
Old May 19, 2003 | 09:25 AM
B2FiNiTY's Avatar
Thanks a lot.
Old May 19, 2003 | 09:26 AM
.RJ's Avatar
.RJ
oh yeah, change the oil and coolant too. oil change is very easy without the intake manifold in the way
you'll need a 4' breaker bar for the coolant drain on the front of the block.
Old May 19, 2003 | 09:36 AM
B2FiNiTY's Avatar
I plan to keep the intake manifold on the head so that it will be easier to pull off. The motor is still in the car.
Old May 19, 2003 | 09:39 AM
yoshi234's Avatar
I shoot brides
y j00 pull'n da hed?
Old May 19, 2003 | 09:44 AM
Aaron M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">you'll need a 4' breaker bar for the coolant drain on the front of the block.</TD></TR></TABLE>
all i needed was 18"
B2FiNiTY's Avatar
Default Re: Pulling the head, what should I replace? (yoshi234)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoshi234 &raquo;</TD></TR><TR><TD CLASS="quote">y j00 pull'n da hed?</TD></TR></TABLE>
You gotta pull it out to use it dummy!
Old May 19, 2003 | 10:22 AM
ragejed's Avatar
Default Re: Pulling the head, what should I replace? (SilverB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
all i needed was 18" </TD></TR></TABLE>
I used 12 foot..
Old May 19, 2003 | 10:29 AM
Austin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I plan to keep the intake manifold on the head so that it will be easier to pull off. The motor is still in the car.</TD></TR></TABLE>
Since you have it out...install a Hondata intake manifold gasket, and a Mugen head gasket...hmmm...have I done this before....
Old May 19, 2003 | 11:07 AM
Chris N's Avatar
Lol, you just need a 18" breaker bar and a hammer, or your foot....
.... or a 4 foot breaker bar and NO foot or hammer.
Dennis - are you putting on the new head gasket?
I'd replace everything like everyone said, and change the earl.
Old May 19, 2003 | 11:38 AM
B2FiNiTY's Avatar
Default Re: Pulling the head, what should I replace? (Chris N)
What's EARL?
I might have to install a head gasket if it's not the cam seal that is leaking.
I used a long breaker bar last time to change the coolant. That stuff should be a breeze.
Old May 19, 2003 | 11:56 AM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">What's EARL?
I used a long breaker bar last time to change the coolant. That stuff should be a breeze.</TD></TR></TABLE>
earl is the stuff you put in your engine. you know, that 10w30 stuff, or 5w30 or whatever you use.
Old May 19, 2003 | 12:01 PM
B2FiNiTY's Avatar
Earl is a brand?
Old May 19, 2003 | 12:07 PM
ragejed's Avatar
earl...oil... lol
Old May 19, 2003 | 12:10 PM
jonas's Avatar
what the fizzle is the difference between "head stud" and "head bolt"
Old May 19, 2003 | 12:48 PM
rainmanEK's Avatar
big strong guy
Default Re: (jonas)
Re Use the Head Bolts!
Wont hurt anybody!
Eric
Old May 24, 2003 | 07:21 AM
00 FBP ItR's Avatar
Default Re: (rainmanEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainmanEK &raquo;</TD></TR><TR><TD CLASS="quote">Re Use the Head Bolts!
Wont hurt anybody!
Eric </TD></TR></TABLE>
Yup
ARP doesn't torque down less than stock can
That's according to IB.. so thats if you wanna take jeff's word.. lol
who wouldn't.. IB
Old May 24, 2003 | 01:21 PM
Reid's Avatar
Global Moderator
Default Re: (00 FBP ItR)
Being that head bolts stretch each time you torque them down, I would replace them only because they are cheap insurance.
I'm sure you could use them 2-3 times without having them stretch too much, but why bother?
Old May 24, 2003 | 03:58 PM
Tommy_Gunns's Avatar
Default Re: (jonas)
A stud has no hex head, a bolt does (ie. a stud is threaded on both ends). That's the difference between a stud and a bolt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonas &raquo;</TD></TR><TR><TD CLASS="quote">what the fizzle is the difference between "head stud" and "head bolt"</TD></TR></TABLE>
Old May 24, 2003 | 04:41 PM
EVIL_AWD's Avatar
Default Re: (Tommy_Gunns)
So for those of you running ARP fasteners, which do you prefer, head studs or bolts?
Old May 24, 2003 | 05:42 PM
rainmanEK's Avatar
big strong guy
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Being that head bolts stretch each time you torque them down, I would replace them only because they are cheap insurance.
I'm sure you could use them 2-3 times without having them stretch too much, but why bother?</TD></TR></TABLE>
They run about $80.00 for oem Head Bolts!
Thats why i re use them 2-3 times!
Eric
Old May 24, 2003 | 08:02 PM
GokuSSJ4's Avatar
you shouldnt have any problems with re using your head bolts
Dennis are you also doing your valvetrain ? if not ,you should and take the advantage of having the head off ....
EnjoyTheRideDC2
May 23, 2007 10:45 AM
Dj^BaNNeD
May 19, 2007 02:02 PM
WTB AUTO EK
Jan 14, 2006 10:21 AM
RS94
Feb 17, 2003 10:40 PM
Edwin
Jul 16, 2002 04:51 PM
