quick question: rear brake calipers????
Old May 18, 2003 | 02:18 PM
Heinz57's Avatar
Default quick question: rear brake calipers????
hey guys...i'm changing the rear brake pads of a friends GSR, and i can't seem to get the rear caliper to swing up...i took the bottom bolt off and the heat shield....i even loosened the top bolt to the caliper...what am i missing? or is it just rusted upp????? thanx
Old May 18, 2003 | 02:45 PM
Heinz57's Avatar
Default Re: quick question: rear brake calipers???? (Heinz57)
calllin out an sos
Old May 18, 2003 | 03:08 PM
real9999's Avatar
They don't swing up like the fronts. Take out both bolts and remove the entire caliper from the bracket.
Tom
Old May 18, 2003 | 03:14 PM
ingrate's Avatar
25 Year Member
Default Re: quick question: rear brake calipers???? (real9999)
did you release the e-brake?
Old May 18, 2003 | 03:59 PM
cjohnson_2's Avatar
Default Re: quick question: rear brake calipers???? (ingrate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ingrate &raquo;</TD></TR><TR><TD CLASS="quote">did you release the e-brake?</TD></TR></TABLE>
that would be my guess as to what you forgot to do.
Old May 18, 2003 | 04:14 PM
VTECorona's Avatar
Default Re: quick question: rear brake calipers???? (cjohnson_2)
I had the same question when doing mine. Take off both bolts and it comes off totally, it doesn't swing up like the front one does. The haynes manual doesn't say this if thats what you're using for reference.
Old May 18, 2003 | 06:18 PM
GSpeedR's Avatar
Default Re: quick question: rear brake calipers???? (97RedTegGSR)
I forget if G3's are the same, but if you have ABS, the wires will still be connected to the caliper. Don't support the calipers by the ABS wires (ie don't hang it with the wires). Bend a coat hanger around the trailing arm (or spring) and suspend the caliper (don't put weight on the wires). It's quite a PITA if they snap.
redd357
May 29, 2010 11:15 AM
Utilitarian
May 8, 2007 06:24 PM
nsxtasy
May 9, 2006 05:45 PM
RNPoo7
Jun 20, 2005 05:59 PM
