Axles for my swap.....?????
Old May 18, 2003 | 02:18 PM
BondoCRex's Avatar
Default Axles for my swap.....?????
Ordered ZC motor, tranny and ecu. Is it at all possible to run any other axles besides the ZC. I've heard they're hard to find. I know you can run the CRX SI tranny and axles, but mine's the base model hence my problem. Any help would be appreciated. (and yes I did a search so keep the flaming to a minimum.) Thanks folks.
Old May 18, 2003 | 02:23 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Axles for my swap.....????? (BondoCRex)
You can use all axles accept for the HF ones. If you dont have the HF you'll be fine.
Blaze
Old May 18, 2003 | 05:32 PM
FourthGenHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BondoCRex &raquo;</TD></TR><TR><TD CLASS="quote"> Ordered ZC motor, tranny and ecu. Is it at all possible to run any other axles besides the ZC. I've heard they're hard to find. I know you can run the CRX SI tranny and axles, but mine's the base model hence my problem. Any help would be appreciated. (and yes I did a search so keep the flaming to a minimum.) Thanks folks.
I have no idea what car you have but this is how it will work...
-If you have a DX or Si with the ZC and you use the ZC Tranny you need 90-93 Integra Axles. If you use a DX or Si Tranny you can use the DX/Si axles just fine.
-If you have an STD or HF you can't use a ZC Tranny because your knuckles outersplines are only 23 and 90-93 axles are 26 like the DX/Si knuckles have. If you are using any of the other trannies then STD/HF axles will work.
Old May 18, 2003 | 08:26 PM
BondoCRex's Avatar
Default Re: Axles for my swap.....????? (FourthGenHatch)
I've got a CRX DX...I've heard twenty different answers to this question but none have been definite.
crxguy406
Jun 29, 2013 09:50 PM
SRZsmack
Jul 6, 2009 04:21 PM
onefiine69
Mar 12, 2005 05:08 PM
onefiine69
Mar 7, 2005 06:42 PM
JDMVTEC
Nov 2, 2003 05:57 PM
