98 civic. . .clutch noise
Old May 18, 2003 | 11:46 AM
Nothing.Special's Avatar
Default 98 civic. . .clutch noise
i have a 98 civic ex. . .and recently, everytime i engage the clutch, it makes a squeaking noise. . .i dont think its a real big problem but its beginning to become annoying. . .any ideas on what it might be?
Old May 18, 2003 | 11:55 AM
Sketch_hs's Avatar
Default Re: 98 civic. . .clutch noise (Nothing.Special)
my 93 civic did the same thing. Does it do it when the car is of when you push down and let go of the clutch pedal? Might just be the return spring, clean it off then re lube it, i used lithium grease and it's all gone!
Old May 18, 2003 | 01:37 PM
Default Re: 98 civic. . .clutch noise (Sketch_hs)
its wen i push the clutch in and when i let off
where is this spring? any pictures of what to do will help me out
Old May 18, 2003 | 01:40 PM
Sketch_hs's Avatar
look up where the pedal goes... there is a spring on it. You'll want a flash light.
near the kick pannel holding the fuses and stuff on my car.
Good Luck!
-Sketch
Old May 18, 2003 | 01:44 PM
thanks, i appreciate it
Old May 18, 2003 | 01:55 PM
Sketch_hs's Avatar
was that the problem?
-Sketch
Old May 18, 2003 | 03:00 PM
havent checked yet as my car is in the bodyshop. . .get it back this week so thats the first thing im going to check
Old May 18, 2003 | 03:46 PM
jeddy0120's Avatar
yeah i am having that same problem too it is really annoying to me as well, i have a 2k1 i just checked it out seems as though it would be a pain to get some lithium up there but i guess its worth a shot i will have to wait for home to do it. Mine only does it when it is warm out or if i am driving the car alot it wont do it if i have not driven in a couple days
Old May 18, 2003 | 04:32 PM
Sketch_hs's Avatar
Default Re: 98 civic. . .clutch noise (jeddy0120)
it's really not that hard, just get under there and spray away... took me like 2 min and no more squeaking...
-Sketch
Old May 19, 2003 | 07:23 AM
jeddy0120's Avatar
alright cool i will give it a try thanks for the help.
Old May 19, 2003 | 07:40 AM
SloCivicHMM's Avatar
Mine sqeeks, but I was told it might be my TOB.......I'll grease the pedal and let ya guys know, you might want to check both out though....
Tht TOB is a pain to get too, dropped the tranny and what not....
sirr6
Aug 20, 2012 08:10 AM
pobomb
Sep 1, 2006 07:36 AM
jaymua
Jul 24, 2006 02:10 AM
96 ls teg
Sep 5, 2004 10:28 PM
HoNdAeX11
Jul 3, 2002 03:09 PM
