b16 parts info...
Old May 17, 2003 | 06:31 PM
misfithamster's Avatar
Default b16 parts info...
hey guys i need to buy some parts for my b16, such as spark plugs, water pump, belts, distributer, gaskets etc... when i go to the local autoparts store what kinda car and year am i buyin for?? if anyone has a list or knows of one online id appreciate it. thanks alot
Old May 17, 2003 | 07:25 PM
Ralph Wiggum's Avatar
I have
NGK SparkPlugs(I'll look at my invoice to find what the serial number is)
DC2 GSR water pump
Del Sol VTEC timing belt and rad hoses and valve cover gasket and a dizzy(BUT YOU SHOULD USE A REMANUFACTURED JDM B16 DIZZY)
DA Clutch cable and axles and clutch
Hasport mount kit
Try to buy OEM Hondaparts for it at cheap internet stores like AHMOTOR.COM or HMOTORSONLINE.
Old May 17, 2003 | 07:39 PM
ScottEK's Avatar
Default Re: (Ralph Wiggum)
Please Read the rules at the top of the this forum:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">6. if you plan on posting a new topic try the search first. it has more than likely been covered before. a link to the search function is below.
https://honda-tech.com/zerosearch. remember to search in the archived as well as recent topics. if the search doesn't work well for you, try to post a specific topic so we all here can answer your questions quickly and correctly.</TD></TR></TABLE>
And now that you know better and will search next time, I will give you what you're looking for (I think I stole this from Home Skillet)
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
***** Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets -8- 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol"
XYRS2LT
Feb 14, 2011 03:16 PM
jweeks
Jun 29, 2007 09:01 PM
sneakerfern
Jan 13, 2007 06:01 PM
efracer
Nov 17, 2003 08:23 AM
jdm_ef9
Mar 22, 2002 06:18 PM
