B16 swap - throttle cable?
Hey, just finished helping a friend swap a JDM B16 into a 97ex.... The throttle cable bracket bolted onto the intake manifold won't work with the throttle cable from the 97ex, what'd the rest of you guys who swapped a B16 in do? As of now we're using the bracket off of the ex, drilling a new hole and bent it to fit better. Is there another bracket that can be bolted in place for a more permanent solution?
man, i'll leave it be till i get one fabbed up at work. Just need to take some measurements and design it quick on a-cad. Lil help from u and we are golden. Maybe i can get a few made for people.
Deffinately dont get a 99-01 si throttle cable. It wont fit. I just did my b16 swap and i made that sad mistake. The si one is too short. An Integra ls cable fit fine for the b16. A GSR will NOT fit so dont make that mistake either. I went with the ls and its dandy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg6LazyPt »</TD></TR><TR><TD CLASS="quote">Deffinately dont get a 99-01 si throttle cable. It wont fit. I just did my b16 swap and i made that sad mistake. The si one is too short. An Integra ls cable fit fine for the b16. A GSR will NOT fit so dont make that mistake either. I went with the ls and its dandy.
definetly dont listen to this guy. because i have a 99/00 SI throttle cable on my b16 powered EH2. do i need to take pictures to show you that it does in fact fit?
how you gonna tell me..when i am the one using one right now..
DBG
</TD></TR></TABLE>definetly dont listen to this guy. because i have a 99/00 SI throttle cable on my b16 powered EH2. do i need to take pictures to show you that it does in fact fit?
DBG
with my swap i used 90 integra ls, because my IM is from first gen b16a. i dont know what manifold you are using... if its the stock 1st gen then try using the ls throttle cable... you might have to move the L bracket one space to have it fit perfect(thats what i had to do to mines)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGsixer »</TD></TR><TR><TD CLASS="quote">
DBG</TD></TR></TABLE>
Woa chill out man, dont get ur panties in a bundle. He is asking for a jdm b16. and you seem to have a usdm one so how do you know its the same? take pics if you want, but how can you tell ME when i am using the LS one right now BECAUSE the SI didnt fit?
DBG</TD></TR></TABLE>Woa chill out man, dont get ur panties in a bundle. He is asking for a jdm b16. and you seem to have a usdm one so how do you know its the same? take pics if you want, but how can you tell ME when i am using the LS one right now BECAUSE the SI didnt fit?
sorry buddy but im about 99.9% sure that there is no difference in the US and JDM b16. maybe you should of tried a little harder with that SI throttle cable..cause it does indeed fit..
</TD></TR></TABLE>sorry buddy but im about 99.9% sure that there is no difference in the US and JDM b16. maybe you should of tried a little harder with that SI throttle cable..cause it does indeed fit..
I have a JDM B16 and trust me there are several differences between the US and JDM models
I would do one of a few things
1-SI throttle cable
2-ITR intake mani
3- USDM Throttle body (JDM one trys to go the wrong way)
1-SI throttle cable
2-ITR intake mani
OmGitsKINNY
Mar 29, 2008 04:01 PM
