"Genuine Honda" fluids vs. name brands
Old May 17, 2003 | 04:33 PM
timzak's Avatar
Default "Genuine Honda" fluids vs. name brands
I have an '03 Accord i-4 and I'm used to doing my own maintanence on my other two cars ('94 Mustang GT and '95 Accent). I'm seeing warnings all over the manual and underhood stickers saying to use only geninue Honda fluids.
Are their fluids really unique, or can I confidently use other brands?
Specifically, what about Honda's Type 2 coolant? I like to keep a gallon of coolant to top the resevoir off...must I use Honda Type 2, or will other anti-freeze brands work equivalently?
Thanks,
Tim
Old May 17, 2003 | 04:42 PM
hs2000's Avatar
Default Re: "Genuine Honda" fluids vs. name brands (timzak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timzak &raquo;</TD></TR><TR><TD CLASS="quote">I'm seeing warnings all over the manual and underhood stickers saying to use only geninue Honda fluids.</TD></TR></TABLE>
If their are warnings I would use the honda stuff. Maybe just me though. Might void your warrenty if you don't.
Old May 17, 2003 | 05:05 PM
ITR764's Avatar
Default Re: "Genuine Honda" fluids vs. name brands (hs2000)
uses all honda fluids except for motor oil.
Old May 17, 2003 | 05:58 PM
B U N M A N G O's Avatar
other brands will work, but there's one Honda type that comes pre-mixed 50/50 w/ distilled water, so you won't have to do it. Just more convenient I guess.
Old May 17, 2003 | 06:56 PM
sr3rd's Avatar
whats up buddy
auto or manual&gt; auto use what mfg recommends manual i bet u it says to use motor oil 10w30 is whats recommended, coolant depends on the ingredients used by the mfg. this ones up to you. i've been using the green stuff for some time now no problems with my crx good luck
Old May 18, 2003 | 04:53 AM
enemy's Avatar
I think Honda coolant has a special formulation for aluminum block engines, that's why it's recommended you use it. I read this online somewhere.
Old May 18, 2003 | 02:19 PM
fe519's Avatar
Default Re: "Genuine Honda" fluids vs. name brands (enemy)
in my opinion, i personally think when it comes to coolant, anything is fine
Old May 18, 2003 | 03:23 PM
timzak's Avatar
Thanks for the feedback. I've got free coupons for a carwash and oil change that I'm going to redeem at the dealer when my first oil change is due. I'll pick up a gallon of the coolant while I'm there to use for topping off. Better safe than sorry, i guess.
Thanks again.
Old May 18, 2003 | 11:31 PM
KingJeff's Avatar
Default Re: (timzak)
What about tranny fluid? Ive heard a lot of good things about REdline. Does anyone have experience with that brand?
Old May 19, 2003 | 12:08 AM
georgeda's Avatar
I had some time to kill at AutoZone so I looked at the lables on the different brands of anti-freeze. None listed any particular make of car or any specification numbers.
I didn't look, but in the past power steering and transmission fluid gave the manufacturers specification numbers that it met.
I don't think Honda tells what specification numbers are for these fluids - only that you should use HONDA fluid.
Old May 19, 2003 | 10:38 AM
jweller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enemy &raquo;</TD></TR><TR><TD CLASS="quote">I think Honda coolant has a special formulation for aluminum block engines, that's why it's recommended you use it.</TD></TR></TABLE>
thats pretty much the jist of it. it needs to be silicate free, or high silicate, one or the other, i always forget. I just use honda coolant and then I don't have to remember
I would also reccomend using their MTF/ATF as well
Old May 19, 2003 | 10:51 AM
KTeller8's Avatar
Default Re: "Genuine Honda" fluids vs. name brands (jweller)
honda stuff is just like 10w40
Old May 19, 2003 | 12:34 PM
jweller's Avatar
Default Re: "Genuine Honda" fluids vs. name brands (KTeller8)
I don't think the MTF is just 10w40. it definately had a slightly different smell to it than motor oil typically has. almost smelled like mineral oil
Old May 20, 2003 | 06:42 PM
hondajj's Avatar
Manual trans Fluid is 10w30 DO not USE GEAR OIL; also Honda Coolant is just a mixture of 50 / 50 so no Mixing as far as I know there are not that Many Coolant manufactures out there.They buy the Coolant and Put there Label on it like most retailers do ; we use Havo automatic trans fluid unless car is new then it gets honda trans fluid, other than that the POWER steering fluid ya deffinatley always want to use Honda Brand.
Old May 21, 2003 | 08:05 AM
ib69nu's Avatar
i went to advance auto, and they told me to just use 10w30. I told them i was gonna check with the dealer.
I asked the dealer for some honda MTF and he said to just use 10w30 oil.
Old May 21, 2003 | 08:53 PM
twkdCD595's Avatar
Default Re: "Genuine Honda" fluids vs. name brands (ib69nu)
As long as you get a green basic coolant your ok... do NOT get dexacool or whatever its called (it is orange colored fluid).
caliskier
Aug 11, 2008 08:50 AM
Black98sh
May 30, 2006 11:41 AM
SOHCMAN
Jan 5, 2005 12:25 PM
RAS Motorsports
Oct 10, 2004 12:11 PM
James
Aug 6, 2003 07:23 AM
