weird sound when stepping on clutch
Old May 17, 2003 | 01:43 PM
SublimeStyles
Guest
Posts: n/a
Default weird sound when stepping on clutch
about a few days ago this clicking sound happens when i step on the clutch. is there something lose? thanks in advance
Old May 17, 2003 | 01:48 PM
garados's Avatar
Default Re: weird sound when stepping on clutch (SublimeStyles)
what kind/year car do you have?
Old May 17, 2003 | 02:05 PM
SublimeStyles
Guest
Posts: n/a
Default Re: weird sound when stepping on clutch (garados)
i have a 2000 gsr.
Old May 17, 2003 | 03:00 PM
jonoknut's Avatar
you should be little more specific than a clicking nosie, is it temporary always there? does it last for a while? wheres it coming from? you on stock ot aftermarket clutch?
jon
Old May 17, 2003 | 03:11 PM
SublimeStyles
Guest
Posts: n/a
Default Re: weird sound when stepping on clutch (jonoknut)
im on my stock clutch. i have 30k miles on the car. it seems like the pedal is loose but i check and its not. when i step on the clutch it would "click."
for example: just like the lid pencil would click when u press it. well thats how it sounds when i step on the clutch pedal. anyone kno wats goin wrong?
Old May 17, 2003 | 03:27 PM
HuskerHybrid's Avatar
i also have this problem, if i step the clutch ALL the way down to the floor, and it has to be all the way engaged, i get a fast clicking noise, it doesn't stop until i let off.
Old May 17, 2003 | 04:52 PM
mattL's Avatar
all i can say is i think its common, i have it once in a while. it comes an goes, but i've seen many posts on this and no one ever know what it is, which makes me think that its nothing broken cause by now someone would have said, "oh guess what my clutch started clicking right before (*****) broke" know what i mean. people usually say that it could be your master cyl, but mines been doing it for 20k miles and nothings broken.
Old May 17, 2003 | 09:14 PM
j99Lude's Avatar
if it's a sqeaking type sound, try spraying some white lithium grease on the shifter linkage.
I tryed that and the shifting has been much smoother, almost no resistance and quieter
Old May 17, 2003 | 09:24 PM
HKJ's Avatar
HKJ
Default Re: (j99Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j99Lude &raquo;</TD></TR><TR><TD CLASS="quote">if it's a sqeaking type sound, try spraying some white lithium grease on the shifter linkage.
I tryed that and the shifting has been much smoother, almost no resistance and quieter</TD></TR></TABLE>
he's not hearing clicking from his shifter, he's hearing it from the clutch when he steps on it
Old May 17, 2003 | 10:39 PM
integraL's Avatar
Default Re: (HKJ)
yeah mine does that once in a while..it doesnt seem to be a HUGE problem. mine went away...
Old May 18, 2003 | 12:36 AM
SublimeStyles
Guest
Posts: n/a
Default Re: (2001gsRguy)
thanks for the replies guys. as for the noise it is slowly goin away. its much quieter now but still clicks.
Old May 18, 2003 | 12:50 AM
Web_Head's Avatar
New User
My 96 teg used to do that. My 02 SI now does it(33,xxx miles). I think it is some flaw with the way Honda designed it.
Old May 18, 2003 | 02:26 AM
4DeepCivic's Avatar
Default Re: weird sound when stepping on clutch (Web_Head)
Has anyone tried to check or bleed the clutch fluid?
How about this.... There are 2 switches on ur clutch pedal. 1 switch is for starting the car, the 2nd switch is for your cruise control. Maybe that's what making the noise... Anyone tried greasing the the hinges on the pedal? Just my $.02
Old May 18, 2003 | 11:36 AM
94gsr4dr's Avatar
Default Re: weird sound when stepping on clutch (4DeepCivic)
to the person that said that it makes the sound when the pedal is all the way down but stops as soon as he lets off, go get your clutch adjusted it is prolly putting to much pressure on your throwout bearing whcih will cause premature failure, also mine makes a squeeking sound as it is pressed down i think it is something in the linkage. Not to scare people but the last time it started squeeking and having some of the symptoms listed above i ended up craking the stock disk and having one of the springs in the hub shoot of the disk.
Old May 18, 2003 | 02:38 PM
Nighthawk GS-R's Avatar
New User
Default Re: weird sound when stepping on clutch (94gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">to the person that said that it makes the sound when the pedal is all the way down but stops as soon as he lets off, go get your clutch adjusted it is prolly putting to much pressure on your throwout bearing whcih will cause premature failure, also mine makes a squeeking sound as it is pressed down i think it is something in the linkage. Not to scare people but the last time it started squeeking and having some of the symptoms listed above i ended up craking the stock disk and having one of the springs in the hub shoot of the disk. </TD></TR></TABLE>
I've always wondered what caused that sound. I get on my 2001 when i press the clutch all the way down.
Old May 18, 2003 | 02:45 PM
sergio's Avatar
I get the same thing with my 2001 LS, although it has not happened in a long time. It would come and go sometimes. This was only when I pressed the clutch petal all the way down. Seems to be normal.
Old May 18, 2003 | 02:46 PM
thanks for the advice, would this be something i would be able to do? or will you have to drop out the tranny to do this? thanks
Old May 18, 2003 | 02:53 PM
migs's Avatar
Default Re: weird sound when stepping on clutch (HuskerHybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HuskerHybrid &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for the advice, would this be something i would be able to do? or will you have to drop out the tranny to do this? thanks</TD></TR></TABLE>
Too much pressure? I dont think thats possible since its all a hydraulic system. If anything, it wont have enough pressure because it needs to be bled.
My clutch squeeks but thats because its a cheap Exedy clutch. I never got that with my stock clutch.
Old May 18, 2003 | 04:14 PM
JunIntegra's Avatar
Default Re: weird sound when stepping on clutch (Migs)
mine clicks too. everytime i push the pedal, about half way down, it clicks. doesnt seem to be much. i tried listening to see if it came from the tranny but didnt hear a thing. o well
LandeZak
Sep 9, 2013 10:38 PM
xkrntamax
Honda Civic (2006 - 2015)
Sep 19, 2009 02:37 PM
siboii08
Mar 27, 2008 08:35 AM
jdmcivicferio
Jul 9, 2004 02:15 PM
95TEG
Mar 7, 2002 10:09 AM
