12.97@ 107.5 last night!!
well this may not be all that impressive to you guys but im happy with the results.
Car made 238 whp just recently in detroit after having the hondata tuned. First time at the track a week ago on old slicks the car's best was a 13.22 @ 106. Well after getting new slicks yesterday i went back to the track hoping for a 12 sec pass. Turned out i hit a 12.97 the first pass of the night. more seat time hopefully 12.50's are possible>
rt .675
60' 1.968
1/8 8.4
mph 85.46
1/4 12.97
mph 107.56
rt .675
60' 1.968
1/8 8.4
mph 85.46
1/4 12.97
mph 107.56
sweet there is hope. I pritty much have the same setup with some extras but that is a very good time.
what tranny are you you useing and if you dont mind tell a little about you setup like weight and suspension.
thanks -pat
thanks -pat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkripper94 »</TD></TR><TR><TD CLASS="quote">if you dont mind tell a little about you setup like weight and suspension.
thanks -pat</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickda6 »</TD></TR><TR><TD CLASS="quote">congrats- thats a tough car to run 12's with...</TD></TR></TABLE>
why is that????
nice times by the way and im sure he is running a 3 in exhaust (i would)
why is that????
yes i know my numbers are low. 8.8 compression B16 with a 50 trim t3/t04b and a LS tranny.
whoever said the car should run those times on street tires with full exhaust all i can do is laugh!
those are very nice times
there are always gonna be the people with there friends car that runs faster , or i know this dude but i really dont but he runs 10flat with 220hp on spare tires
**** guys give him props its a good time
there are always gonna be the people with there friends car that runs faster , or i know this dude but i really dont but he runs 10flat with 220hp on spare tires **** guys give him props its a good time
laugh all you want but you should really take a look at your car and laugh
91 rs integra nothing stripped
rev hard stage 2 turbo kit, 10 psi
thermal 3 inch exh
act 6 puck/xtreme pp
koni yellow's
skunk 2 coil overs
12.8@106 on the stock, shity tires
11.9 @117 on 15 psi and 24.5x8 m&h slicks, that was letting off about the 1000 ft mark, we hit rev limiter in 4th gear.
ls trans also.
thermal 3 inch exh
koni yellow's
skunk 2 coil overs
ls trans also.
good times! once u get the car the car back on the tracks u'll most likey be running even better....just driving the car and getting used to it can improve times! good luck...
and everycar is different just cause one runs a # doesnt mean that the same kinda car is going to even if it has the same set up..............
great times! but just because your car did this doesnt mean that every car can and will. all tracks/cars are different but good numbers nonetheless.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic »</TD></TR><TR><TD CLASS="quote">laugh all you want but you should really take a look at your car and laugh
thermal 3 inch exh
koni yellow's
skunk 2 coil overs
ls trans also.
ok but you probably have quite a bit more hp.
is that with a b16a as well?
thermal 3 inch exh
koni yellow's
skunk 2 coil overs
ls trans also.
b18b, keep in mind...stock engine and stock rev limit, 6800 or so.
i hit a similar time yesterday at my semi local track here in CA. i went 12.91@112 on a stock block 1.8 all motor street car....but i was on street tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i need space »</TD></TR><TR><TD CLASS="quote">i hit a similar time yesterday at my semi local track here in CA. i went 12.91@112 on a stock block 1.8 all motor street car....but i was on street tires. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic »</TD></TR><TR><TD CLASS="quote">true. very true
these times were from atco raceway, nj.
good luck with the car though..
Doesn't Atco speedway average a corrected altitude of 100' below sea level? Where G2TURBO races there is a corrected altitude of 492' above sea level, quite a difference that must be recognized.
</TD></TR></TABLE>Doesn't Atco speedway average a corrected altitude of 100' below sea level? Where G2TURBO races there is a corrected altitude of 492' above sea level, quite a difference that must be recognized.
Nextelbuddy
Jun 19, 2004 09:32 PM
