sunroof suicide
Guest
Posts: n/a
ok ok i have a 91 si hatchback with the sunroof and lately we have been getting bad storms and it seems to be leaking out of 2 of the corners of it. everytime it rains really hard it drips all over my seats and gets the interior wet has anyone ever had this problem before and what is a cheap solution to it because its really bugging the **** out of meand i only have like 200 dollars to spend...thanks. oh yea i took it to a valvoline just to get a friends eye view of it and he said it looked like it just needed to be resealed could that be the problem?
reseal it, thats the problem w/ rexs both the hatch and the sunroof leak after time.
Plus the hatch does not stay up.
plus it rust.
plus...thats all i can think of.
you can buy a new rubber peice, or just get a new sun roof for under that 200 you want to spend
plus it rust.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speed_racer012 »</TD></TR><TR><TD CLASS="quote">
Duct Tape
Duct Tape
yeah my sunroof was all rusted out and wouldn't work so i sust took it off and then hold it of with duct tape.
took it to the car wash and everything and it didn't leak at all
Guest
Posts: n/a
i was gonna ask about that too if i put in a fiberglass pannel does it look like ****? ive heard of people doing it but ive never seen it does anyone got any pictures of thier sunroof removed? how much will it cost for sealent and how much will it cost for a fiberglass pannel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huggy Bear »</TD></TR><TR><TD CLASS="quote">new seals, and take a air hose, and blow out the drain tubes</TD></TR></TABLE>
yeah, this is the first guy so far to mention the drain tubes, they're a pretty common problem too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cingham »</TD></TR><TR><TD CLASS="quote">why not just do this
1. get a phone book
2. call honda
3. get price</TD></TR></TABLE>
HAHAHAHAHA thats fucked up but damn hahahahaaha
that would be a $500 job at the dealer
1. get a phone book
2. call honda
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sihatchback »</TD></TR><TR><TD CLASS="quote">what happens with the drain tubes? and what are they what do i look for? whats the best way to fix them if they are broke?</TD></TR></TABLE>
the drain plugs justgetplugged up with all kinds of dirt and stuff so that water can no longer flow down them, and if the water cant go down there, it has to go somewhere - in the car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvlErn69 »</TD></TR><TR><TD CLASS="quote">
that would be a $500 job at the dealer</TD></TR></TABLE>
$65 to clear out the drain tubes at my dealer.
i havent done this because i have a dx, but if you had to reseal, could you just use silicon temporarily until you get new seals?
but first solution would be to remove panel, blow out the drain tubes as allerady mentioned.
then maybe silicon it back up, or duct tape it back.
Im am facing the same problem right now. The things the Helms says to check for water leaks:
1. Clogged drain tube
2. Gap between glass weatherstrip and roof panel
3.Defective or improperly installed glass weatherstrip
Guest
Posts: n/a
ok just so everyone knows i havent fixed the problem yet but i figured out what to do....me and a good friend of mine looked and found the drain tubes...they are towards the front of the car and they are just little holes...on the passenger side we took a cup of water and poured it into the sunroof resevoir thing and the water poured out of the drain tube and down out by my front passenger side tire...so it was clean as a whistle...then we went to the drivers side and poured water in the resevoir and nothing happened for a sec it just filled to the top of the resevoir and started to drip inside the car...so it was the drivers side tube that is clogged...my friend has an extremely high powered air compressor and tommorrow afternoon iam gonna get some drano and shoot it in the hole and take the compressor and blast all the dirt out if possible..if not then im to the dealer ship......................i have a quick question to anyone out there though-are there only 2 drain tubes because thats all i found is there 4 or 2?????please answer me someobody-thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sihatchback »</TD></TR><TR><TD CLASS="quote"> i have a quick question to anyone out there though-are there only 2 drain tubes because thats all i found is there 4 or 2?????please answer me someobody-thanks</TD></TR></TABLE>
There are 4. Two in front, two in the rear. I'm not sure where the rear ones come out on a hatch. On 2 and 4 doors they are in the trunk behind the wheel wells.
