FS: B series parts
Old May 17, 2003 | 11:28 AM
Jaker's Avatar
Default FS: B series parts
I have the following for sale. All these items are in good running order, or brand new.
ITR LSD, tapered bearing on one side, but the other side failed, so its gone. No ring gear. Speedo drive is there. Will fit any 94-up GSR transmission, or any B series tranny with the GSR or ITR ring gear and some minor internal modding. $375
Honda OEM B16/ITR intake manifold gasket, brand new, $10
Honda OEM GSR intake manifold gasket, brand new, sold
Honda OEM B series valve cover gasket set, brand new, sold
B series axles and intermediate shaft from 99 Intagra LS, sold
2 Honda OEM motor mounts from 90-93 Integra, the one that goes just below the cam pulleys, and bolts directly to the aluminum block, and the one that attaches to the tranny, and goes back to the rear crossmember. These are the 2 mounts that you usually need when putting a B series into an EF, using one of the bolt in motor mount kits. sold
Endyn RollerWaves pistons, 84.5mm for B series (B20 or sleeved and overbored B16/B18), high compression (around 12.7:1 in a B20 Vtec), includes wrist pins, but no rings. $300
Hondata Stage 2 with dataloging and rom emulator. All you need is access to the software and an eprom programmer to do your own tuning. P06 ECU converted to Vtec, and Hondata ready included, $550. Possibility of a few bonus parts included.
New Parts
Shift linkage setup from 99 Integra LS. Includes shift lever, shifter rod, and stabilizer rod, plus as a bonus you get an Energy Suspension bushing in the end of the stabilizer, where it attaches to the tranny. $75
More new parts
B series starter from 99 LS $ 50
B series alternator, OBD1, unknown origins, but works great $50
Modified by Jaker at 8:55 PM 5/26/2003
Old May 17, 2003 | 04:39 PM
Jaker's Avatar
Default Re: FS: B series parts (Jaker)
Up to the top
Old May 18, 2003 | 03:21 PM
Jaker's Avatar
To the top!
Old May 18, 2003 | 03:41 PM
Frog's Avatar
Good guy to buy from
Old May 18, 2003 | 11:08 PM
Jaker's Avatar
Default Re: FS: B series parts (Frog)
He boule de graisse!
Old May 19, 2003 | 06:52 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frog &raquo;</TD></TR><TR><TD CLASS="quote">Good guy to buy from </TD></TR></TABLE>
i second that notion...
Old May 19, 2003 | 08:16 PM
Jaker's Avatar
What? Nobody wants any of this cool isht?
Old May 19, 2003 | 08:29 PM
Jaker's Avatar
Default Re: (Jaker)
Pics of the diff
Old May 20, 2003 | 05:01 AM
Jaker's Avatar
Default Re: (Jaker)
To the top
Old May 20, 2003 | 06:55 AM
lowcivex's Avatar
Default Re: (Jaker)
ill take the valve cover gasket for 20 shipped
Old May 20, 2003 | 07:42 PM
Jaker's Avatar
Default Re: (lowcivex)
Thanks for the offer, but thats not enough.
Old May 21, 2003 | 07:02 PM
Jaker's Avatar
To the top.
Old May 23, 2003 | 01:49 PM
Jaker's Avatar
Up again.
Old May 23, 2003 | 02:24 PM
Si-Yaaa!'s Avatar
Are you sure those are the mounts needed for putting a b18c1 into an EF? I think I need the tranny mount, but not sure about the other. If you know for sure, then I'll take the two of them. Let me know, thanks!
---Evan
Old May 23, 2003 | 03:11 PM
Jaker's Avatar
Default Re: FS: B series parts (Si-Yaaa!)
Have a look here at the Hasport site for info on the mounts needed.
http://www.hasport.com/Tech/Installs/EFB1.htm
The 5th picture down is the tranny mount, and the before last picture's description give the details on the other mount.
Let me know.
Old May 23, 2003 | 05:29 PM
Si-Yaaa!'s Avatar
Ok, it sounds like the rear bracket is definetely the one I need from you and probably the other one you have, it only said a JDM b16a (first gen). So how much shipped to Ca 92673?
Old May 23, 2003 | 05:34 PM
TRuST's Avatar
Are the prices in USD or CDN ?
Old May 23, 2003 | 07:42 PM
Si-Yaaa!'s Avatar
Default Re: FS: B series parts (TRuST)
bump, I need those mounts
Old May 23, 2003 | 07:52 PM
revhigh96's Avatar
what needs to be done to put the diff in a GS-R tranny? I might be interested.
Old May 23, 2003 | 11:03 PM
Jaker's Avatar
Si-Yaaa,
The mounts would be $60 shipped.
revhigh96,
The diff would drop right into any 94-up GSR tranny. All you need is 1 tapered bearing.
TRuST,
The prices are USD.
Old May 24, 2003 | 02:51 AM
Si-Yaaa!'s Avatar
Oh wait a sec, are these the mounts or the brackets for a mount kit like the hasport mount kit? I believe I need the bracket not the mounts. If they're the brackets, I'll take them and you can PM me your info for payment. Thanks!
Old May 24, 2003 | 09:33 AM
Jaker's Avatar
There's alot of confusion about the various terms used to describe these parts. They are the parts that you need to attach your motor to the Hasport Mounts (or other brands).
I have PM'd you with payment info.
Thanks
Jacques
Old May 24, 2003 | 04:41 PM
Si-Yaaa!'s Avatar
Paypal sent. Let me know if you got it. Thanks!
Old May 25, 2003 | 08:44 PM
Jaker's Avatar
To the top with edits.
Old May 26, 2003 | 09:05 AM
Jaker's Avatar
To the top!
