Injector Problem???
I have a 91 crx si wit a 95 gsr swap i am using the crx harness and also the crx injectors i need to get new injectors i have the stock gsr injectors but they don't fit i was told to use LS injectors but wat year fits i know i could use obd0 ones but they are too much money i was also told i could cut the harness and use the gsr injector clips too wat should i do????
you can use 90-91 integra injectors or 88-91 SI injectors. You can use the GS-R's if you still have the harness from the motor b/c the injector plugs are different between the harnesses. You also will need to remove the injector resistor box if you use 92+ injectors unless you use 92-96 preludes
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flexmyREX »</TD></TR><TR><TD CLASS="quote">i got some 90-91 ls injectors, 25 bux</TD></TR></TABLE>
or 88-91 d16a6 injectors (si/ex). they all flow the same 240cc.
