FS: 96 Civic SPC aluminum rear lower control arms
Asking 150$ + 10$ shipping
Part No. 69100
Used for about 3 months. Converting car to stock.
original post https://honda-tech.com/zerothread?id=408156
LCA's info from specialty Products:
http://www.spcperformance.com/....html
Modified by mrlegoman at 8:51 AM 5/17/2003
Modified by mrlegoman at 1:59 PM 7/2/2003
Part No. 69100
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR »</TD></TR><TR><TD CLASS="quote">I'm interested in the beaks kit & the LCA's - sent you a PM :D thanks - Greg</TD></TR></TABLE>PM'd you back
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOME »</TD></TR><TR><TD CLASS="quote">How do these aluminum ones perform? Are they that much better than stock?</TD></TR></TABLE>Performance wise I did not notice ANY difference. I have to drill out a frozen bolt on my stock ones, so it gave me an excuse to buy these. They do weigh a little less, but not much. They look 100% better then stock (which is at least worth a 5 hp gain).
They are a little bit shorter than stock (which means you must have a camber kit). The reason is so that if you are running wider tires, you can keep the car lowered without the tires rubbing the fender.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b2b »</TD></TR><TR><TD CLASS="quote">bump for you man! any luck on the black car?</TD></TR></TABLE>
Get this.
I had stripped the car down to stock. Bought some used stock shocks, switched back to the drums. About 6 hours of work into the car.
The I was finishing up on the last rear drum when the guy said his kid liked the koni's and rear disk. So before I got it aligned I re-installed EVERYTHING back on the car (rear disk, koni's,and camber kit). Another 6 hours of work.
Got it aligned (Honda charged my 140$ because of the excess labor involved with the camber kit)
They take it for a test drive. And then offer me 4500$.
I said 4500$ would be great for a STOCK car. But I have another 1000$ worth of suspension that they asked me to put on there. The dad said to the kid "well thats more than what we talked about"!!
So I got screwed and they didn't even kiss me.
I have another father/son team look at it last night, but I think their going to blow me off too.
So now I probably have to return it back to stock (another 6 hours) to get a broader market of buyers.
So to answer your questions: $hitty.....really $hitty.
Get this.
I'm not 100% sure off the top of my head.
I would like to say about a 1/2 inch, but again I'm not 100%. Let me find a tape measure and I can measure from them.
I would recommend a camber kit.
Think it would work on my 99 civic ex, with 99 teg rear disc swap?
-PHiZ
Sounds similar to your application. And I'll give you 10 dollars over whatever scrapinSI offers you! heheh j/k
-PHiZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ »</TD></TR><TR><TD CLASS="quote">Think it would work on my 99 civic ex, with 99 teg rear disc swap?
</TD></TR></TABLE>Yup, the 96's and 99's had the same LCA.
I had a GSR swap on mine and it worked fine.
BARTEG
Jan 5, 2008 10:01 AM
PupaScoopa
Aug 5, 2005 08:52 PM
SPD DMN
Jun 8, 2005 10:44 AM
mrlegoman
May 18, 2003 09:22 AM
