OIl on spark plugs
Old May 17, 2003 | 07:32 AM
sacredc0w69's Avatar
Default OIl on spark plugs
Was doing an oil change today and while at it decided to check brakes and spark plugs...
pulled each one out 1 by 1 and noticed that there was oil on each one...
they were covered even the white part had oil on it...
so i cleaned each one off and put it back in to check for oil, cuz i figred it just leaked threw when i was pouring in new oil...however after pulling the plug out again there was oil at the bottom of it...any ideas on what the problem may be?
and why i'm getting oil over the spark plugs...?
Old May 17, 2003 | 09:21 AM
Chiovnidca's Avatar
Default Re: OIl on spark plugs (sacredc0w69)
Spark plug tube seals maybe?
Old May 17, 2003 | 03:38 PM
RUBZERK's Avatar
Default Re: OIl on spark plugs (Chiovnidca)
Check your valve cover rings gaskets
Old May 17, 2003 | 04:53 PM
timzak's Avatar
Can we get a little more info on your car? Year, miles, etc? Don't want to scare you, but it sounds like a serious prob...worn valve guides or piston rings, according to my Haynes manual.
Old May 17, 2003 | 06:43 PM
ib69nu's Avatar
Default Re: OIl on spark plugs (timzak)
actually, more than likely it is just spark plug tube gaskets. just replaced my valve cover gasket, and the tube thingeys. I would recommend that.
Old May 19, 2003 | 03:18 PM
i got a 1990 5spd lx accord....
uh .... 330k km so like 220k 215k miles?
do the conversion i have no clue...
but uh....i'm hoping its not the pistons and i got the haynes manuel as well i was planning on going threw it maybe finding the problem but time is a factor...and i dont have none stupid work...
but thanks for the help i'll check what u guys told me and i'll let u know what i find out
Old May 22, 2003 | 07:34 PM
Peter Griffen
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timzak &raquo;</TD></TR><TR><TD CLASS="quote">Can we get a little more info on your car? Year, miles, etc? Don't want to scare you, but it sounds like a serious prob...worn valve guides or piston rings, according to my Haynes manual.</TD></TR></TABLE>
I guess I'l ask here instead of making a new thread.
I got a similar problem except the oil is comming up to the ignition wirespast the threads of the plug?
I replaced those O rings like some people said to do, but the problem is still there.
I got a 93 accord lx 125K miles.
Any ideas anyone?
Yes my gas mileage is suffering as well as power.
Old May 23, 2003 | 06:19 PM
DragonTLS's Avatar
oil is seeping throught the rocker arm seals, with miles like that the rocker
arm seals are harden and shrink, if you replace them make sure to replace the
plug well seals also
Old May 23, 2003 | 09:22 PM
i c i c, thanks alot ktls...i'll c if i could take a look at it and c if thats the actual problem...
Old May 24, 2003 | 05:14 AM
integra dave's Avatar
Default Re: (sacredc0w69)
i have a 94 accord wagon which had the same problem when i got it &gt;&gt; i changed the valve cover seal and the spark plug seals &gt; the kit somes complete with everytring you need NOT INCLUDING HONDABOND. buy a tube of that for about 10 bucks US. if the engine is in decent shape the kit should tkae care of the leaking proboem
Old May 24, 2003 | 05:20 AM
carolinaACCORD's Avatar
Default Re: (integra dave)
if the oil is mostly in the spark plug tube and on the wire, it's either the spark plug grommets, valve seals, or valve guides. if it's on the bottom of the spark plug as well, it could also be piston rings. im sure it could be something else, but that's the most common.
Old May 24, 2003 | 06:34 AM
okay thanks alot
murrellington
Mar 21, 2016 05:11 PM
honda.girl.1991
Sep 5, 2013 06:56 PM
smetzger
Mar 31, 2008 10:15 AM
Peter Griffen
Dec 26, 2002 04:33 PM
eastsidemags
Mar 22, 2002 01:22 PM
