VX harness sucks
Old May 17, 2003 | 05:59 AM
H23vtecEG's Avatar
Default VX harness sucks
i put a type-r swap in a 92 VX and so far the wiring has been a pain in the ***. yesterday i went to plug in the O2 sensor
black- B1
white- D14
green- D22
black-A6
well i got nothing but O2 sensor and heater codes than TPS sensor for doing this
than i went to wire up the Knock sensor D3 and theres allready a wire there
oh yeah the 92 VX has 7 wires coming out the O2 sensor which is also confusing me. should i wire up the O2 like i did above or are the VX pins different.
any of you guys run through the same thing with the VX?
Old May 17, 2003 | 06:06 AM
H23vtecEG's Avatar
Default Re: VX harness sucks (H23vtecEG)
i forgot to mention that i'm using a 95 Vx ecu which has the 4 wire O2 sensor.
when i first put the swap in it wouldnt start. than i wrapped a dax harness around it. the car started right away, so then i put back the VX harness back on without doing anything to it and it started. why wouldnt it start in the first place. man i give up, i'm going to the junkyard to get an EX complete harness
Old May 17, 2003 | 06:24 AM
degooser's Avatar
so ur putting a odb I harness on an OBD II motor???
dont u have like extra plugs just laying around??
try using a vtec obd II harness and a chipped p28 ecu...
Old May 18, 2003 | 05:36 AM
H23vtecEG's Avatar
Default Re: VX harness sucks (degooser)
no extra plugs. i wrapped the Vx harness around the R and no extra plugs like i had with the type R harness. plus i want OBD1 wiring
90AccordVTEC
Oct 11, 2005 09:34 AM
Aespooncivic
Jun 8, 2005 04:40 AM
ChrisDaun
Feb 12, 2004 04:25 AM
SOUNDEFFECTS
Jan 23, 2003 12:22 PM
