stock B20 vtec in ef timeslips
Old May 17, 2003 | 12:59 AM
desert eagle's Avatar
Default stock B20 vtec in ef timeslips
whats the average et for B20 vtec in 88-91 civics?
stock head and block.
non drag radial tires?
drag radial tires?
slicks?
Old May 17, 2003 | 02:22 AM
J2turbo21's Avatar
Default Re: stock B20 vtec in ef timeslips (B20vtec81)
I think a guy in a crx ran 14.3-14.5 with a stock b20 motor swap.
Old May 17, 2003 | 04:20 AM
UncleBen'sRacing's Avatar
Default Re: stock B20 vtec in ef timeslips (J2turbo21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">I think a guy in a crx ran 14.3-14.5 with a stock b20 motor swap.</TD></TR></TABLE>
damn well whoever did that did something wrong, or cant drive
i ran a 14.3 with a stock b16 in my 90 hatch, thats with 150 whp, and a b20vtec has around 184 whp..... you do the math
Old May 17, 2003 | 04:29 AM
J2turbo21's Avatar
Default Re: stock B20 vtec in ef timeslips (AllMotorEF9)
Crap all i saw was b20.He ran those times with just a stock b20,not a b20 vtec.
Old May 17, 2003 | 05:46 AM
bottlefedb18c1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorEF9 &raquo;</TD></TR><TR><TD CLASS="quote">
i ran a 14.3 with a stock b16 in my 90 hatch, thats with 150 whp, and a b20vtec has around 184 whp..... you do the math</TD></TR></TABLE>
is that with slicks or street tires?
Old May 17, 2003 | 06:24 AM
Tr0LL's Avatar
Default Re: stock B20 vtec in ef timeslips (bottlefedb18c1)
wow... i hope my civic cx can do low 14s with just a stock b20... here's to hoping...
Old May 17, 2003 | 08:12 AM
highbrid's Avatar
Default Re: stock B20 vtec in ef timeslips (Tr0LL)
i ran a 13.3 at 102.5 with a stock internal b20vtec in my eg, on slicks, no vafc, stock injectors, type r cams
Old May 17, 2003 | 10:17 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: stock B20 vtec in ef timeslips (highbrid)
I saw a bone stock B20 block w/ a bone stock B16 head, H23 throttle body, 3" intake and Open JDM 4-1 totally untuned lay down 154whp. I then saw that motor transplanted into a 1600lb EF race car because the guy spent all of his money on the chassis and go 12.80 @ 100mph. As far as I know the motor is completley built now.
P.S. The trap speed is not a typo.
Old May 17, 2003 | 10:19 AM
did u run a 92-95 hatch (white w carbonfiber hood)on like 15 or 16 inch enkeis with slicks?
@ firebird?
Old May 18, 2003 | 02:17 AM
highbrid's Avatar
that was me, 15 inch rim 22 inch slicks, did you see me there? Im on dragracing.com too with that car
Old May 18, 2003 | 08:17 PM
LaminaR X's Avatar
I have 90 crx si with B20 block(B20B)with B20Z pistons,GSR head with full type R internals,and stock GSR manifold with 60 mm throttle body,all this is tuned with HONDATA fuel system.Stock clutch with double diaphram plate and jap spec XSI
transmission,with LSD.The car ran a best et of 12.92@108 with slicks(22-8-15)
60 foot best time is 1.82,but usually does 1.90s.Shift points are at 8500 rpm but have been as high as 9500 rpm.
Rob . check out more at http://www.autolaminar.com
Old May 19, 2003 | 06:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottlefedb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">
is that with slicks or street tires?</TD></TR></TABLE>
on streets
Old May 19, 2003 | 10:59 AM
JDM CRX's Avatar
someone up above said he ran a lower 14 with a bshiteen in a 90 HB...Is it fully stripped?
-i have a 88 HF CRX 1997LBS with driver, B16,LSD intake, stock header, exhaust with cat,
best on Slicks was a 14.7 @ 93 MPG 2.2 60' time with a .505 R/T
i know the 90 HB weighs at least 300 LBS more than my HF (1819lbs)
WTF
Old May 23, 2003 | 06:10 PM
Default Re: stock B20 vtec in ef timeslips (JDM CRX)
thats just driver prob, and b16's some are more powerful than others, i dont know why
mine was: 90 hathc stripped 2050 lbs (weighed)
2.197 60ft
14.38@94.94
street tires
Old May 23, 2003 | 07:02 PM
skwert_720's Avatar
I ran a 14.44 at Norwlk (ohio) with a B18B I,H,E, and fpr on drag radials. I thought that was pretty good.
Old May 24, 2003 | 09:18 AM
LSiTurbo's Avatar
Default Re: stock B20 vtec in ef timeslips (skwert_720)
One of our shop cars went 13.9@99 on drag radials with a stock b20vtec in a 91 crx si with full ent.
Old May 24, 2003 | 09:54 AM
Default Re: stock B20 vtec in ef timeslips (LSiTurbo)
90 hatch si
that sound extremely on point. alot poeple claim extremely low times w stock b20 vtec and b16s. i ran 2 14.7s and a 14.50 @ 95 mph w faulty distributor off of a ls.
thats on shiity street tires. i think realistic 13.7 - 13.8s with some rubber. right now my 60 ft is 2.3 - 2.4.
Old May 24, 2003 | 04:05 PM
smokey2.0's Avatar
i have a b20z bottom end with a b16 head, stock gsr valve train, no cold air intake, fidanza chipped pr3 ecu, jdm s1 tranny, 15" falken azenis tires(pressure set at 32 psi). on a 88 crx, full interior my best run was 14.1@100mph, with a 2.2 60', major grind going into second gear(broken pressure plate)! i think once i fix my tranny issues, the car can hit 13.7 with no problems. better times are to come with better parts!
Old May 25, 2003 | 09:59 PM
highbrid's Avatar
Default Re: stock B20 vtec in ef timeslips (smokey2.0)
i have a buddy who also ran a b20 vtec who ran 13.1 @ 101 with stock block, head porting and vafc, but sort of the same setup as in my car in my sig
Old Aug 21, 2003 | 12:08 PM
redlineb18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CRX &raquo;</TD></TR><TR><TD CLASS="quote">14.7 @ 93 MPG</TD></TR></TABLE>
That's some good gas milage!! Way to help out the fuel economy
Old Aug 21, 2003 | 12:18 PM
SadisticRacing's Avatar
14.38 doesn't sound that far off to me I have a '90 Crx with full interior and I've ran 14.4@95.38 with my B16. It's all how you drive!!
Old Aug 22, 2003 | 12:04 AM
V-SPEC 1's Avatar
Default Re: stock B20 vtec in ef timeslips (SadisticRacing)
I have a b20vtec setup not high comp. on eg. I have'nt run the car yet to the track because it's not broke in yet. What do you guys think I run with this setup? minor bolt on. Thanks.
Old Aug 23, 2003 | 09:32 PM
Default Re: stock B20 vtec in ef timeslips (boostedb20vtec)
ran two 14.4 @ 96.7 mph 2.23 60ft.
the second run would have been faster but i had a flaw.
but def cacable of low 14s the way it sits
Modified by B20vtec81 at 11:46 PM 8/23/2003
Old Aug 24, 2003 | 12:31 PM
thankyou i cant belive that **** for 2 seconds!
Old Aug 24, 2003 | 04:40 PM
Norcalstoppy's Avatar
I'm pretty sure high 13s is possible.
Jay Kim
