OBD1 injector question
I know when you do this you need injectors, but what if you do use the stock injectors? Will it work or not? And I thought I read somewhere a while ago, that you can convert to obd1 and still use your stock injectors just ground them off somewhere, or something, or is there only a way to use obd1 injectos? Any help is appreciated.
BTW I searched, and didnt find the topic..
you have 2 options....Use your stock injectors with the resistor box or OBDI with no resistor box. you have this same option even if you stay OBD0. OBD0 are peak/hold and low impedance while OBDI and II are saturated and high impedance.
surkitroller
Dec 29, 2009 12:58 PM
D.Dappa
Jan 18, 2005 06:56 AM
