crank angle sensor
hey whats up? I have a 89 civic si and I put the 97 del sol sohc vtec engine "d16y8" and i am using the p28 ecu from a 92-95 civic sohc vtec. I found the crank angle sensor on the drivers side of the block it has 3 wires white, blue and black, I know the black goes to ground but i do not no where the other two wires go. I know they are sensor inputs I was wondering if they go to the distributor. I need to fix this because i am throwing codes four and nine, and i hope this will help
crxnonvtec
Aug 28, 2009 11:12 AM
