hook up FICV on MPFI?
Old May 16, 2003 | 12:30 PM
G2turbo_terror's Avatar
Default hook up FICV on MPFI?
okay, I am now among the hundreds of people to post about the mpfi swap.
engine: 1990 D15b2
mpfi parts- 91 d16a6
there is a 2 wire, wire harnes on my fast idle control valve and I cant figure out where to hook it up. My helms doesn't show a fast idle valve on my previous manifold.
Also on the TPS sensor, where I'm supposed to switch the green/white and yellow/white wires, my green/white wire was not connected to the the tps plug. I also have a ground wire on there. Am I supposed to wire in the green/white and just cut yellow/white? People always say "just switch the two wires..." thats why I'm asking.
Old May 16, 2003 | 01:23 PM
91civicEX's Avatar
I did the mpfi and i didnt hook up the FICV and theres no problems. theres also a plug not used on the DX harness but it doesnt fit. For the TPS the outside wires switch places and the middle one stays.
Old May 16, 2003 | 01:24 PM
Hondasaurs's Avatar
Default Re: hook up FICV on MPFI? (G2turbo_terror)
This is the info you need.
http://www.hybridgarage.com/te...g.htm
The only thing that will be different is the blue/green and blue/yellow wires. They will go to your distributer plug.
On the TPS (3 wires) -- Easily put -- Switch the 2 outside wires. Thats it. They will also need to be extended.
chad
Jun 14, 2008 08:05 AM
4thgenHB157
Feb 17, 2005 05:23 PM
HybriDNA
Feb 12, 2003 05:44 PM
SOUTHCREX
Jun 16, 2002 05:26 PM
