Motor is going crazy after drop Help me please help me please!!!!!
Old May 16, 2003 | 09:32 AM
Redsunz916's Avatar
Default Motor is going crazy after drop Help me please help me please!!!!!
Man just got finished dropping my new motor in this teg and its acting wierd... for one it idles irradic like up and down up and down from where ever it sits and second engine light pops on and idle goes Sky rocket... When u first start it goes into about 1800 rpm and bounces like 50 rpm up and down.. then a few seconds later engine light pops on and booom 3000 rpm and then u thikn u rev it to stop the high rpm from holding it goes strate down to make u think its gonna die but it doesnt it sits at about 300 rpm for a few seconds then it dies??? i am about ready to burn this whole project its pissing me off Help me please what can i do? what are possiblities of the problem im getting to the point where im gonna give up hope on this car! HELP PLEASE FOR THE SAKE OF A HONDA! Btw its a 1993 Integra Ls
Old May 16, 2003 | 09:37 AM
turbob18a1's Avatar
is this the stock engine,replacement engine , swap, or built . please specify
Old May 16, 2003 | 09:39 AM
The-LS's Avatar
Default Re: Motor is going crazy after drop Help me please help me please!!!!! (Touchless)
if you got a CEL, its obvious you have to check them especially after a swap where so many variable have changed.
Old May 16, 2003 | 09:47 AM
J337_UNIT's Avatar
did u swap ecu's?
Old May 16, 2003 | 10:05 AM
WiggiE's Avatar
New User
Default Re: Motor is going crazy after drop Help me please help me please!!!!! (Black-LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-LS &raquo;</TD></TR><TR><TD CLASS="quote">if you got a CEL, its obvious you have to check them especially after a swap where so many variable have changed. </TD></TR></TABLE>
Check the CEL
It might slightly help us if you tell us what engine and ecu you are running as well.
Old May 16, 2003 | 12:51 PM
intekragsr's Avatar
Default Re: Motor is going crazy after drop Help me please help me please!!!!! (WiggiE)
set your ignition timing, cam timing, adjust the valves, all sensors plugged in, and tell us the cel code.
Old May 16, 2003 | 04:53 PM
piatl7il77's Avatar
Default Re: Motor is going crazy after drop Help me please help me please!!!!! (intekragsr)
What about the vacuum lines they all atached and in the right places?
Old May 17, 2003 | 12:16 PM
Redsunz916's Avatar
i thikn im missing my no2 control box? its a 18a1 and its all stock from ground up
Old May 17, 2003 | 01:14 PM
WiggiE's Avatar
New User
Default Re: (Touchless)
Don't even worry about posting here if you aren't going to listen to the advice given. Checking your CEL takes two seconds to do, and has zero negative effects. It is a very good way of diagnosing an engine problem.
Old May 17, 2003 | 03:58 PM
Redsunz916's Avatar
True True i am listening by the way... It just frustrated the hell out of me on top of that i can only post 5 a day o well off to check the CEL see what this thing shows....btw how do i become a normal member? its tuff trying to get advicewhen u cant even respond?
Old May 17, 2003 | 07:41 PM
Westrock2000's Avatar
I forgot to plug in my crank angle sensor when I did my swap. It didn't like that to much. Thats the sensor that wraps around the crank pulley. I think it idled at 30000 rpms for a minute.
aLlmoTorcoUpe
Honda Civic (2001 - 2005)
Apr 8, 2009 06:40 PM
skata89
Dec 12, 2007 11:01 AM
nonv
Dec 3, 2004 08:11 AM
95accordracer
Dec 26, 2002 07:13 PM
