how do I change rear brakes in fifth gen lude
Ok I know its easy to some of you. But I dont want to mess up. How do I change my rear brakes. Will it be easy? someone please help thanks,
James
James
I could not get anywhere on the link...
The rears are the same as the front.
Just pull one of the "thru" bolts rotate the caliper up remove the old pads...
use a LARGE screw driver and turn the piston back into the caliper.
Put new pads in and reassemble.
