b16...whcih plug wires?
Old May 16, 2003 | 06:16 AM
type Gendy's Avatar
Default b16...whcih plug wires?
I have been trying to get rid of a nasty hesisation in my car for about a month now. Tried a new Cap, and new plugs..... still there. So i pulled the wires yesterday and one of the ends just broke off when i pulled it out fo the distributor...
What wires should i get?? NGK's are $82 around here.... need them asap because the set that is on there now decinagrated, and they are about 5 months old.
Modified by sick hatchem at 3:58 PM 5/16/2003
Old May 16, 2003 | 07:04 AM
type Gendy's Avatar
Default Re: b16...whcih plug wires? (sick hatchem)
Or should i get OEM 94 del slo vtec wires?
Old May 16, 2003 | 07:12 AM
matt j's Avatar
i would say either run the ngks or factory honda, i had a buddy that ran both ngk and honda wires on a dyno run and he got more power with the honda wires.
Old May 16, 2003 | 07:21 AM
raene's Avatar
I'm using del Sol VTEC wires, Accel 300+. No problems so far (year and a half later).
Old May 16, 2003 | 09:15 AM
slowpokesi's Avatar
Default Re: b16...whcih plug wires? (mattED6)
i rock the magnecore 8.5mm they are really high quality and the ends seem to go on better than stock, i paid 95 bucks for them.
they are for a delsol
if you need something now you could always get a set from autozone or somewhere for 30 bucks until you can get some new oem ones or ngk or magnecores
Old May 16, 2003 | 10:11 AM
ricodemus's Avatar
Default Re: b16...whcih plug wires? (slowpokesi)
honda oem wires are made by ngk. As far as your hesitation, you sure its not an o2 sensor problem?
Old May 16, 2003 | 10:38 AM
Hondasaurs's Avatar
Check to see if your rotor is loose. That will cause hesitation. As for plug wires I'm running MSD B18C wires. They are the same for all DOHC Vtec models.
Old May 16, 2003 | 02:11 PM
type Gendy's Avatar
Default Re: b16...whcih plug wires? (B17A Hatch)
K, thanks guys, just picked up some del sol ngk wires...
As for the hesistation, i am lost, gonna try these wires and see what happens. I dont think its an o2, no codes, and the rotor is tight, however i have a new one i am gonna replace it with.
The hesistation happened after i put in a knock sensor and calibrated the TPS. All codes went away. Hesistation started, got progressively worse. Now i have a code 22, so i pulled the vtec solenoid, cleaned it, and put new gaskets in it.
Guess i will go see where i am at.
Old May 16, 2003 | 04:29 PM
type Gendy's Avatar
UPDATE::
I put on the new wires tonight. Went to start it, and it wont even run. If i give it gas, it sounds like a 600 hp mustang, jumping all over the place. IT sounds horrible, i dont know whats wrong. None of the wires are crossed. Please help!!
Old May 17, 2003 | 07:02 AM
Hondasaurs's Avatar
Check all the wires on the cap again. Make certian they are inthe right firing order. Did you get a new cap. Somtimes, inside the cap, there is a small pin that can go bad. It touches the coil. Check this. Also double check your rotor. Make sure its tight as hell. It can only go on one way (it has a small flat spot on it in the shaft), when you replaced it did you force it on did you?
Old May 17, 2003 | 07:16 AM
FourthGenHatch's Avatar
Yeah OEM Honda is NGK. Do OEM Honda ones come in the blue color, because I know the NGK ones you buy are blue, I was wondering if since NGK makes OEM Honda if they are really the exact same wires.
jason_SIR
Jan 20, 2014 07:12 PM
marvinmark21
Jan 14, 2008 12:06 PM
DrivinVtec
Sep 10, 2007 07:02 PM
intevic_dx
Apr 29, 2006 12:44 PM
gray_civic_coupe
Jan 9, 2006 10:51 PM
