Went to the track last night....
Here's the lowdown.
99 civic
h22a4 ('99)
Internals are Stock
short-ram intake 2.5" exhaust 2.5" carsound cat, N1 muffler
weighed 2400 without me. and just over 2600 with me
My best time was 14.61 @ 94
I felt the car hook really good off the line, but I misshifted 3rd, and it was still the best run of the night...go figure
Edit: Also on one of my runs I misshifted from 3rd and went to second.....now it seems that my car has a sligth miss at idle...but other than that it seems to run great. Anyone got any ideas about that?
Thanks
Mark
99 civic
h22a4 ('99)
Internals are Stock
Thanks
Mark
that would be some slightly bent valves.
run a compression check and I'll bet $100 that some of your cylinders compression numbers are off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlvrEj6Dx »</TD></TR><TR><TD CLASS="quote">Also on one of my runs I misshifted from 3rd and went to second.....now it seems that my car has a sligth miss at idle...but other than that it seems to run great. Anyone got any ideas about that?
yeah, that doesn't sound good at all, defiantly check that out or get it check out soon.
ot: Lone i see you changed you avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX »</TD></TR><TR><TD CLASS="quote">
ot: Lone i see you changed you avatar</TD></TR></TABLE>
I was tired of having my steering wheel up there. It was time to have the powerplant and turbo represented.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">run a compression check and I'll bet $100 that some of your cylinders compression numbers are off.</TD></TR></TABLE>
Yeah....my homie has a bore-scope so I'm gonna see if there was any piston/valve contact.
Mark
Mark
yeah, sounds like some valve issues...theres alot of people going from third to second..ive only done it like twice, but it never even jumped over 5 grand, i could feel the car start to nosedive, and immediately pushed in the clutch, but ive seen people like slam it into second gear and full gas...sounded horrible.....i think people need to be more careful and more practice, no offense to you in this thread just in general
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeRacer023 »</TD></TR><TR><TD CLASS="quote">yeah, sounds like some valve issues...theres alot of people going from third to second..ive only done it like twice, but it never even jumped over 5 grand, i could feel the car start to nosedive, and immediately pushed in the clutch, but ive seen people like slam it into second gear and full gas...sounded horrible.....i think people need to be more careful and more practice, no offense to you in this thread just in general</TD></TR></TABLE>
hey guys, it only takes two fingers to shift that bitch. its not like the shifter is gonna fight back! The reason ya'll seem to do this is all tensed up haulin *** and gettin too antsy! chill, and let the H series ride out! its not like it wasnt gonna do it anyway!
first time i let anyone drive my car is when i went home on leave. my dad is racing it down the backroads. 8,000 rpm in third gear (according to the tach which we all know is off) shift to second on accident. BAM!!!! needle is burried. shut the car down, thank god nothing is wrong.
I'd do a valve adjustment and see if that cures your problems. You could have just caused the valve lash to get very loosened. You can have a minorly bent valve or valves and the car can still run alright, sucks to be stuck with it though.
Ok check it out.
Did a compression test, got 215,200,195,205
Then I did a leakdown test, and all were just over 40% (which is considered "moderate" leakage)
I also busted out the bore-scope, and it *seemed* that the exhaust valve releifs had clean indentions on them, and that was on all cylinders.
My friend works in the honda parts dept., and I work in a shop.....so I guess its time to lap some new valves in
Or maybe its time to get some skunk2's?
Although I had an offer for a trade to a b18c1, and I just might take it. I like the torque of the h22a, but the fitment in a civic is bad, and the solid mounts make my car shake bad with the A/C on... Permission to flame granted....I dont care...
Mark
Or maybe its time to get some skunk2's?Although I had an offer for a trade to a b18c1, and I just might take it. I like the torque of the h22a, but the fitment in a civic is bad, and the solid mounts make my car shake bad with the A/C on... Permission to flame granted....I dont care...
Mark
T3T495GSR
May 20, 2003 09:40 PM
