going insane with rear clip on climate control
Old May 16, 2003 | 01:35 AM
Mr. Softee's Avatar
Default going insane with rear clip on climate control
trying to change it tonite, the rear clip just does not want to come out of the freaking climate control. ive tried just about anything. anyone have some very specific instructions on that clip? i dont wanna the CC side becuase i realize that if it doenst clip in its gonna fall out when I try to put the green one in.
Old May 16, 2003 | 02:43 AM
canuck-mx6's Avatar
Default Re: going insane with rear clip on climate control (94goldjungsr)
What rear clip? There are two screw under the rear defrost and hazzard switch. You have to remove the heater cable by leaning under the dash on the passenger side. It is easily removed. Then you pull then control slightly and just unplug the two cables attached to it, and then remove the climate control
Old May 16, 2003 | 08:50 AM
Mr. Softee's Avatar
Default Re: going insane with rear clip on climate control (canuck-mx6)
GEE THANK YOU FOR THAT INSIGHT.... YOU ARE A GENIUS.
I asked about the rear clip. KTHXBYE.
Old May 16, 2003 | 09:20 AM
siis2fast's Avatar
well smartass, i guess when you say 'rear clip" you should be alittle more specific about what that is
Old May 16, 2003 | 11:25 AM
canuck-mx6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">GEE THANK YOU FOR THAT INSIGHT.... YOU ARE A GENIUS.
I asked about the rear clip. KTHXBYE. </TD></TR></TABLE>
If you weren't such a smart ***, I might have posted the helms page for you along with explicit instructions, considering I just swaped my climate control two nights ago.
Old May 16, 2003 | 12:21 PM
Jonmon's Avatar
maybe this will help..... http://www.team-integra.net/se...D=586
I did the article myself.
Old May 17, 2003 | 01:57 PM
DB8_TEG's Avatar
Default Re: going insane with rear clip on climate control (Jonmon)
would anyone know where I could get the little and I mean little bulbs to replace in the climate control? I have a few that are burnt out. would i have to go to an Acura/Honda dealer to get them cause I doubt that any stores would store bulbs like these ones.
Tsakai
May 11, 2018 05:41 PM
Rickmirelez
Honda Civic (2006 - 2015)
Dec 13, 2010 05:46 AM
shackler
Jan 28, 2007 09:57 AM
