Funny question, about trans?
I know that this is probably a real dumb question, but I refilled my trans in my b16a after installing it into my 89 DX CRX. I know that it holds around 2 quarts, I filled until it started to leak out. Is this good enough, do I have to refill up, or check level agian after I drive, and get it going?????
No, you will not need to fill it up again, unless you have a leak. If you filled it till it poured out of the fill hole a little, then it is full. Check for leaks, if you have none, then you're good to go.
