integra spring rates
does integra spring rates on a civic make it not as low as it should be on a integra?
i got some integra springrate coilover, and i install the back and slammed it all the way, and now i still have 1-2 finger gap. do i have to break them in or is it just because it is integra rates?
I'm assuming correct..
I have EK spring rate springs on my EG...my friend has the same on his EK and his are way lower than mine.....
TEG rates should yeild the same results..
i have integra spring rates on my car and they sit pretty low, then again i'm on 17's
however, since the integra rates are higher, the eg body doesn't weigh enough to compress them as low as an integra body would. also, there is a "break in period," shouldn't take too long depending on how new the coilovers are. after mine settled in it sagged an additional half inch.
BoostinEJ1
May 2, 2004 08:17 AM
