what is wrong, i don't know
car: 89 civic dx motor w/ 141k auto
here's my problem, before i had a coolent leak at where the water pump is located, i think it is because of the old seal.
so after replacing new (used water pump from junk yard) and with new seals, now my car feels like it is powerless when in low tourqe........meaning when the car starts going in first gear, the padel feels hard and i have to give it alot of gas, stepping harder to get the car to move, same thing in 2nd gear and 3rd gear.....
so what is going on? before the change i used to get like 280 to 300 miles a tank and now only like 230 or 240 or so.........
is it because of my timing?
thanks
thanks
i think the bearings are good, and about the timing belt my friend and i set it to TDC, and i think is pretty tight also.........i will double check when i have time....
it just lag like **** now............
and no car is not overheating now.......temp is normal
This is def. a timing issue... take it to a mechanic.. shouldn't charge you more than 50 bucks to fix... also, what the hell are you doing buying a used waterpump? Thats just plain stupid... you dont even know if it is good... I would have gone all out and got new if I was gonna do this!
yea, i am thinking it is a timing issue too.........maybe set incorrectly? or something? i am cheap, don't wanna pay 50 bucks to fix it, DIY.
and the water pump....... it didn't cost me a single dime for it
yes, is still good when i put it in
BLeSR
May 16, 2010 07:08 PM
Contender25
Jun 9, 2005 07:10 PM
