Honda S2000 Honda S2000
Self-made grounding wires installed
Old May 15, 2003 | 07:04 PM
KW-AP1's Avatar
Default Self-made grounding wires installed
I made my own grounding wires yesterday and got it installed today. Thanks to my friend Chris who gave me his HKS battery terminal mount.
I think i feel better accerleration in the low end and a little better throttle response
Old May 16, 2003 | 05:02 AM
blacks2000's Avatar
Default Re: Self-made grounding wires installed (KW-AP1)
Notice anything else? Brighter headlights, or anything like that?
Old May 16, 2003 | 08:53 AM
Blue-Civic-Hybrid's Avatar
Loved
Where did you install your wires at? which ground points? did you sandpaper the points with paint on them?
Old May 16, 2003 | 10:36 AM
jerrypeterson's Avatar
HUH? How in the world would this provide additional horsepower? Did you verfy with a before/after dyno run? If anything it looks like you added five pounds of weight to the car.
Old May 16, 2003 | 11:12 AM
blacks2000's Avatar
Default Re: Self-made grounding wires installed (jerrypeterson)
I don't think it would make any additional power, but I have heard that electrical sytems runs more smoothly after doing this. Of course, its all word of mouth...I havent seen the results personally.
Old May 16, 2003 | 07:44 PM
sslude's Avatar
Default Re: Self-made grounding wires installed (blacks2000)
you THINK it gave you better acceleration..only a dyno may prove that.
Old May 18, 2003 | 10:21 AM
ScubaStevo80's Avatar
Default Re: Self-made grounding wires installed (sslude)
Check import 2nr, they're done a number of tests for ground wires, and all have actually shown horsepower increases, whether minimal or up to 10hp like they found on the rx7 or wrx (i forget which).
What type of cables and ring terminals did you use? What else did you use for the install, I'm thinkin of doing this on my civic.
Old May 18, 2003 | 08:00 PM
microbomb's Avatar
Default Re: Self-made grounding wires installed (VolpeOwnsU)
I think I remember reading in a couple issues back of turbo mag that they were able to increase the hp of a WRX by about 5hp with a grounding kit, however I don't understand the concept behind it.
Old May 18, 2003 | 10:11 PM
volkracing99's Avatar
New User
Default Re: Self-made grounding wires installed (microbomb)
I use Hyperground wire, and I like it... brighter light, better respond...
http://www.sunautomobile.com/
and this dyno chart from350zforum.com
Old May 19, 2003 | 09:46 AM
Default Re: Self-made grounding wires installed (volkracing99)
OK I still don't get it. You posted two dynos of a 350z and the second one is running a leaner mixture. "Gee, it made more power when I leaned out the mixture." If those dynos were for real, you would see more power with the same fuel mixture becuase 'ignition efficiency' improved. THAT IS NOT GOING TO HAPPEN.
Claims of 10hp on a WRX by adding some wire are crazy. Do you seriously think the stock electrical system on a car is so deficient? Come on guys, this is snake oil. If your lights are dim, and there isn't enough juice flowing to your coil packs, you have bigger problems than the need to supersize a ground wire.
Old May 20, 2003 | 08:45 AM
jolt-tsp's Avatar
When I grounded the headlights on my civic back to the battery directly, they stopped flickering. So that was cool.
Seems like more direct grounding points could help a lot of things out including HP, but I don't think it'd really be noticable unless you studied a dyno very closely.
Old May 20, 2003 | 12:42 PM
B2FiNiTY's Avatar
Looks good
Old May 21, 2003 | 11:23 PM
CWESTINAP1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerrypeterson &raquo;</TD></TR><TR><TD CLASS="quote">OK I still don't get it. You posted two dynos of a 350z and the second one is running a leaner mixture. "Gee, it made more power when I leaned out the mixture." If those dynos were for real, you would see more power with the same fuel mixture becuase 'ignition efficiency' improved. THAT IS NOT GOING TO HAPPEN.
Claims of 10hp on a WRX by adding some wire are crazy. Do you seriously think the stock electrical system on a car is so deficient? Come on guys, this is snake oil. If your lights are dim, and there isn't enough juice flowing to your coil packs, you have bigger problems than the need to supersize a ground wire.</TD></TR></TABLE>
Don't knock it till you try it.
Nice Job KW-AP1
btw, gas mileage is increased, along w/ throttle response, stereo, and lighting.
H22aAccord
Sep 5, 2004 12:32 AM
frog1623
Aug 18, 2003 10:57 AM
fASTBACK
11
Feb 11, 2003 06:38 PM
[HrZn]4life
Feb 3, 2003 12:02 PM
PRoJecTSLeePaLoT
Jul 9, 2002 09:56 PM
