What size tires?
Old May 15, 2003 | 06:43 PM
Thrillhouse's Avatar
Default What size tires?
What size tires do you guys recomment for stock 99 ls mesh rims? My friend recomended 215/45/15 does that sound right and does any one have any pitures? BTW i have a 1.5 inch drop.
Old May 15, 2003 | 06:55 PM
00VTEC's Avatar
Default Re: What size tires? (Thrillhouse)
195/55/15 or 205/50/15
Old May 15, 2003 | 07:05 PM
Any pics?
Old May 15, 2003 | 07:06 PM
DR3AM's Avatar
Default Re: What size tires? (00VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00VTEC &raquo;</TD></TR><TR><TD CLASS="quote">195/55/15 or 205/50/15</TD></TR></TABLE>
Old May 15, 2003 | 07:08 PM
WiggiE's Avatar
New User
215's are definitely too wide for the stock rim. Alot even say a 205 is too wide too. But either a 205/50/15 or 195/55/15. Anything else will either not fit or throw off your total diameter by too much.
WTF do you need pics of tire sizes?
Take a ruler, measusre out 205mm. That is approximately how wide a 205/50/15 tires is.
Old May 15, 2003 | 07:11 PM
Default Re: What size tires? (WiggiE)
sry on me i want to see what the tire gap would be with the tires you guys suggest. Im sorry I should have been more detailed.
Old May 15, 2003 | 07:28 PM
WiggiE's Avatar
New User
Tire gap? As in the gap between the tire and the fender?
If so, all of these tires are going to have the exact same tire gap. You don't want to change the overall diameter of your tire & wheel combo.
Old May 15, 2003 | 11:08 PM
Goldfingiz's Avatar
195/55/15
Old May 15, 2003 | 11:53 PM
xteg95's Avatar
Default Re: What size tires? (Goldfingiz)
they dont make 45s for 15s, id say go w/205/50/15.
Old May 16, 2003 | 12:15 AM
Aaron M's Avatar
Default Re: What size tires? (xintegra01)
205/50/15
Old May 16, 2003 | 12:39 AM
B2FiNiTY's Avatar
Stock size. The wheels are not wide enough to optimize the use of wider tires.
Old May 16, 2003 | 07:09 AM
pnthr30's Avatar
Default Re: What size tires? (B2FiNiTY)
I put 205/50/15 on the stock mesh wheels and no problems........... I have a 99 GS sedan. I will try to take some pics for you tonight and post them. You can go up to 205 on the stock wheels, anything wider will not work.
sinister357
Feb 12, 2007 07:46 AM
integracura
Jan 2, 2007 06:06 PM
AiL45
Dec 22, 2006 06:59 AM
B3AS
Oct 25, 2006 10:58 AM
Powered By Garrett
Mar 7, 2005 08:13 AM
