working on my new system, would someone help?
right now ive got 2 12 rf's i got from a friend . my old shiz got stolen, but im getting it replaced by insurance, so i plan on keeping the 12 inch L7 im getin from them . then ill get another one in about a month. the thing is i want to build a vented enclosure for these L7s in my rex. i want to keep it in the back storage area, behind the backseats would be if it was jdm y0, ha,
but im new in making vented enclosures. so if someone would be so kind as to help me.....? by the way the amps ill be running to them will be 2 rf 400s's. my friends got it hooked up to 2 L7s, and its really loud!. wow loud. ok . but would someoen help?
What help do you need exactly? I would use the kicker recommendations. If you need help calculating port length then that is not too hard. Once you figure out how big the box is going to be, decide what you want to tune it to. Then port length can be determined depending on how big you want the port to be.
Playing with winisd can help alot also.
how could i fit a vented enclosure big enough for 2 12 L7s in the back of my crx?
i dont really know how to build vented boxes, i was asking for some help, i want the vents on top, the kicker plans on their site have them on the side.
ehhh screw it ill just make a big sealed one.
If you want a vented enclosure then build it
You will like it.
Give me the maximum box size(external) that you can get in there and I can help you out. You can put the ports up, or facing forward. Facing up limits the length of the port without bending it. It is easier to put the ports on the side.
You will like it.Give me the maximum box size(external) that you can get in there and I can help you out. You can put the ports up, or facing forward. Facing up limits the length of the port without bending it. It is easier to put the ports on the side.
ok ill find out the outside dimensions i can make the box then ill get back to you sometime so you could help me. i do want to make the ported enclosure, so thanks for helping me.
Kyles ej1
Sep 26, 2004 07:09 AM
merlyn
Dec 15, 2002 10:39 AM
