manual tranny rebuild
Old May 15, 2003 | 04:39 PM
dominate9's Avatar
Default manual tranny rebuild
My 3rd and 5th gear synchros are gone. So I'm thinking time for a new tranny or rebuild. I know that I will be boosting my H22 in a few month and if I have to rebuild my tranny, I might as well build it really good. Where can I get a manual tranny "bulletproofing" rebuild kit?
Old May 15, 2003 | 08:00 PM
Toretto's Avatar
Default Re: manual tranny rebuild (dominate9)
I am interested in knowing this also. When I have an LSD installed, we will inspect the tranny, if it looks word, I would like to rebuild it.
Old May 19, 2003 | 08:46 AM
CTR94Joes's Avatar
Default Re: manual tranny rebuild (Toretto)
Same here let's get some info up here ppl!!
Old May 19, 2003 | 09:03 AM
Honda318dx's Avatar
Default Re: manual tranny rebuild (CTR94Joes)
Stock factory rebuild is the best I know of.. I blew all my gears this weekend..
Old May 20, 2003 | 04:16 AM
CTR94Joes's Avatar
Default Re: manual tranny rebuild (Honda318dx)
Hey Honda318dx where do you get your tranny internals from or do you know a site where you can buy them?
Old May 20, 2003 | 06:01 AM
Honda318dx's Avatar
http://www.hondaautomotiveparts.com
Old May 20, 2003 | 07:46 AM
dominate9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">Stock factory rebuild is the best I know of.. I blew all my gears this weekend..</TD></TR></TABLE>
So you are saying that a stck tranny rebuild can handle a boosted H22 running like 8 lbs?
Old May 20, 2003 | 08:41 AM
H22Si's Avatar
Very much so. The factory transmissions are <U>very</U> strong, most likely strong enough to handle any amount of power you will ever want to throw at it. What they can't handle for very long is abuse; power shifting, forcing it into gear, regular 7,000rpm dumps, ect. The syncronizers and differential are what take the blunt of the abuse. One small role of the syncronizers is to take the shifting abuse before the actual transmission gear teeth do. If you let your syncronizers grind and whine too long but you still manhandle the tranny, the gears are next in line to fail.
Differential failure is most commonly associated with shock damage, drag racing for example.
Old May 20, 2003 | 08:45 AM
2point6's Avatar
Default Re: manual tranny rebuild (H22Si)
Stock parts are great. If you can, get the synchros Cryogenically treated first. This helps them last a little longer, especially if you are drag racing. Cryo is not a cure, but can extend the life of a part.
Old May 20, 2003 | 08:54 AM
Tofu2.3Vtec's Avatar
i can get stock parts from honda 40% off.. and i have the same problem.. even at my price its over 800 bux.. you need the gears and the synchos.. its better to get a used one.. theres a place in houston that has them .. an Si tranny is 695, if your in houston they will delivery for free, im not sure how much the vtec tranny is.. if anyone wants to know.. check out http://www.asapmotors.com
tmramsburg
11
Apr 12, 2007 05:28 PM
bseries_beast
Jul 24, 2006 12:20 PM
teefunk01
Oct 25, 2005 05:24 PM
