Tial 40mm Wastegate Sale!!!
Old May 15, 2003 | 04:36 PM
Ben Huynh's Avatar
Default Tial 40mm Wastegate Sale!!!
Modified by ben@importparts.com at 12:55 PM 12/31/2003
Old May 19, 2003 | 12:14 PM
Ben Huynh's Avatar
Old May 19, 2003 | 12:42 PM
Mase's Avatar
Default Re: (ben@importparts.com)
Great Prices Ben.
Old May 19, 2003 | 12:54 PM
slowcivic's Avatar
New User
Default Re: Tial 40mm Wastegate Sale!!! (ben@importparts.com)
Ben, how long will these special prices last?
Old May 19, 2003 | 01:07 PM
Ben Huynh's Avatar
Default Re: Tial 40mm Wastegate Sale!!! (slowcivic)
This sale ends June 15, 2003.
Old May 19, 2003 | 01:14 PM
b18bturbo's Avatar
do those come with flanges ben or without on the 40mm
Old May 19, 2003 | 01:21 PM
Ben Huynh's Avatar
Default Re: Tial 40mm Wastegate Sale!!! (b18bturbo)
The flanges are additional.
Old May 19, 2003 | 01:54 PM
Armaan's Avatar
Bump for Excellent CS and prices.
-Armaan
Old May 19, 2003 | 03:02 PM
*Boostwerks*'s Avatar
Is there an external difference from the 40mm and the 40mm HP?
I bought a 40mm "HP" from someone on here, and I was wondering if there is a way to tell without taking her apart.
Old May 19, 2003 | 03:45 PM
Ben Huynh's Avatar
Default Re: Tial 40mm Wastegate Sale!!! (Bryson)
You can't tell the difference by looking at the outside of the wastegate.
Old May 19, 2003 | 04:48 PM
karmannghia's Avatar
Do you sell just the spring? I need a 1 bar spring for the 40 mm one.
Old May 19, 2003 | 06:30 PM
Ben Huynh's Avatar
Default Re: Tial 40mm Wastegate Sale!!! (karmannghia)
Yep, email me for details.
Old May 21, 2003 | 11:05 PM
Universal Magnetic's Avatar
What does the wastegate come with? Does it come with all the bolts, both flanges?
Old May 22, 2003 | 12:41 PM
Ben Huynh's Avatar
Default Re: Tial 40mm Wastegate Sale!!! (@ntiRice)
The wastegate comes with all bolts and hardware. The flanges are additional.
Old May 22, 2003 | 12:45 PM
Boostless97Lude
Guest
Posts: n/a
can someone please tell me the difference between the "HP" and regular models???
i haven't got a clue
Old May 22, 2003 | 12:48 PM
b18bturbo's Avatar
Default Re: Tial 40mm Wastegate Sale!!! (Boosted97Lude)
the hp unit comes with larger valve only difference.
Old May 22, 2003 | 12:53 PM
Boostless97Lude
Guest
Posts: n/a
which accomplshes what exactly
used internal WG in the past, needs to learn new stuff
Old May 22, 2003 | 12:55 PM
b18bturbo's Avatar
the larger sport valve can handle more boost 1.5bar +
Old May 22, 2003 | 10:54 PM
Do you mean there is a mm difference in the actual "valve" of the WG between the HP and normal?
I just thought that the HP had the ability to accpet the larger and smaller springs thus raising it's ability to boost higher.
Old May 23, 2003 | 05:10 PM
Ben Huynh's Avatar
The valve is the same diameter. The difference is in the high pressure spring.
Old May 23, 2003 | 06:15 PM
MotorMatrix.com's Avatar
I am a bad person
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">the hp unit comes with larger valve only difference.</TD></TR></TABLE>
the only difference is the spring rate thats all. up to 1bar is a standard and over 1bar is th HP. you could also combine springs to achieve a rate over 1bar
Old May 23, 2003 | 06:43 PM
You_Get_Vapors
Guest
Posts: n/a
Default Re: Tial 40mm Wastegate Sale!!! (MotorMatrix.com)
So does this mean that the 38mm is going to replace the 35/40 Hybrid? Does the 38mm come with colored tops or only polished?
Old May 23, 2003 | 09:13 PM
b18bturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com &raquo;</TD></TR><TR><TD CLASS="quote">The valve is the same diameter. The difference is in the high pressure spring.</TD></TR></TABLE>
the valve seat is accutally bigger ben take a look fro your self and measure it it slightly bigger but by a very minute amount
Old May 23, 2003 | 09:19 PM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">the larger sport valve can handle more boost 1.5bar + </TD></TR></TABLE>
A larger valve will have more surface area and make it harder for the wastegate to remain closed under high boost. The bigger surface area results it more pressure per sq. in. on the face of the valve, making it's job of holding in exhaust pressure more difficult. A smaller valve and a bigger diaphram is actually better for high boost.
Old May 23, 2003 | 09:27 PM
b18bturbo's Avatar
Default Re: Tial 40mm Wastegate Sale!!! (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
A larger valve will have more surface area and make it harder for the wastegate to remain closed under high boost. The bigger surface area results it more pressure per sq. in. on the face of the valve, making it's job of holding in exhaust pressure more difficult. A smaller valve and a bigger diaphram is actually better for high boost. </TD></TR></TABLE>
HEy tony is that why you guys went back to that other wg
