Need help working with bondo
Old May 15, 2003 | 01:01 PM
Stryker908's Avatar
Default Need help working with bondo
Hey guys I am going to be sanding and primering my car. I have to do it because im sick of this gheto mix and match parts on my car I would rather have it all one color of primer.
My question is, I have never used primer before, and I have a dent in the back that I want to take care of at the same time .. do I just sand it down to bare metal and then apply the bondo and sand down untill it is smooth with the rest of the car correct ? are there any links that will give me an explination on how to do this thanks
P.S. I plan on having everything redone by a pro .. this is just a temp fix
Old May 15, 2003 | 01:25 PM
Stryker908's Avatar
Default Re: Need help working with bondo (Stryker908)
here is a picture of my car, If you look close you can see the diffrent colors in the paint look by the back of the door. The whole front end has been replaced with one from a silver car (you cant tell from the pictures but they whole front is dented and creased it was not fixable)
Also can you use bondo to shave the side moldings ?
Old May 15, 2003 | 02:18 PM
Russ713's Avatar
dAng!
i dont remember the size dent on the rear of the car, but if it's small (door ding) you can just sand it down, and bondo it in, but if it's a larger dent, you'll want to pull/push the dent out as smooth as possible, then use bondo to finish it up.
As for the moldings, bondo to shave moldings with no other work is a bad idea. It'll end up cracking and look like crap.
Old May 15, 2003 | 02:32 PM
tnbigdawg's Avatar
Default Re: Need help working with bondo (Russ713)
i dont recommend spraying your car with those rattle cans....it might not be compatible with your new paint job.
as for the bodywork, sand to bare metal beyond the dent and clean it well before applying bodyfiller. sand with 40grit to roughly shape the filler. finish it off with 80, then 120(or 150). sand down the surrounding paint to get rid of sand scratches with 120/150 then primer.
the whole car should be sanded with 500-600 grit.
Old May 15, 2003 | 04:39 PM
Stryker908's Avatar
Default Re: Need help working with bondo (tnbigdawg)
Thanks for the advice ! is there a primer I can use ? this two tone crap looks bad LOL people keep reving on me LOL its got these gay *** black/green/blue graphics ... ARGGGGG
Old May 15, 2003 | 04:48 PM
Russ713's Avatar
dAng!
hehehe......
REV ! REV !
Old May 15, 2003 | 05:39 PM
Stryker908's Avatar
Ehhh Shut it Russ Dude last night I was rev'd on by that mustang fastback ..LOL I just looked and a laughed .. I been in a fight before it dosent meen im gona take on Tyson ...
Old May 15, 2003 | 07:09 PM
Evs-One's Avatar
Solbros Owns Me
do not use rattle can primer. It does not contain lead and will absorb 200% of its own weight in moisture.
If anything, rent a compressor and buy a cheap spray gun from Craftsman, with some urethane primer, and seal it up....
Old May 15, 2003 | 11:28 PM
tnbigdawg's Avatar
Default Re: Need help working with bondo (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">do not use rattle can primer. It does not contain lead and will absorb 200% of its own weight in moisture.
If anything, rent a compressor and buy a cheap spray gun from Craftsman, with some urethane primer, and seal it up....</TD></TR></TABLE>
"urethane primer SURFACER" is a good route. put on about 2-3 coats so when its time to paint your car with color, just block sand that to get out slight waves that you might have. Get a HVLP gravity feed gun, this will help save paint needed to spray because it doesnt create a lot of overspray. And make sure you get an aircompressor that's up to the task(gallons, HP, CFM's)
raverx3m
Paint and Body
27
Feb 24, 2012 05:16 PM
OddityDX
Paint and Body
14
Jul 26, 2009 01:46 AM
kelviiv
Paint and Body
11
Oct 25, 2007 10:06 PM
thehatchninja
Dec 17, 2002 01:44 PM
Teg44
Jun 20, 2001 12:38 PM
