Would a ek cat-back fit my eg both hatchbacks
Old May 15, 2003 | 09:18 AM
crew08 (girlygirlracer)'s Avatar
Default Would a ek cat-back fit my eg both hatchbacks
i found a sweet deal for a cat-back and would like to know if it would fit my eg hatch. i searched the archives but a lot of mixed up answers. if not would the axleback fit at least? whats interchangeable and whats not? please let me know!
thanks
Old May 15, 2003 | 10:29 AM
Snoopy1's Avatar
Default Re: Would a ek cat-back fit my eg both hatchbacks (crew08)
Do you mean an aftermarket one?
Cause I don't know if they are different or not, but I have a stock 99 Hatch complete header back exhaust on my 92 hatch.
The difference is that the 92-95 had the cat after the header as a separate piece whereas the 99-00 or maybe all of 96-00 had the cat in the header for the hatchbacks. So the difference will be that the EK hatch midpipe will be longer than the 92-95 hatch midpipe, but the axleback portion is exactly the same.
What I have right now is 99 DX hatch stock header, 99 DX hatch stock midpipe and stock axleback. The bends under the car are the same, but I had to shorten the midpipe about 1-2 inches to stop it from rattling.
In order to use it you will either have to run no cat and shorten the midpipe by 1-2 inches, or you could cut the midpipe to the correct length to include a cat, but that would mean cutting off quite a bit of the pipe and either welding it on or putting a new flange on.
My friend with the 99 hatch put my old catback on his and it fit no problem cause he used my testpipe. He posted a topic about the swap a month ago, i think, but I don't remember where he posted it or what the title was. I actually never even looked at it, but what I said is correct cause we did this ourselves.
Hope that helps
Old May 15, 2003 | 11:29 PM
Default Re: Would a ek cat-back fit my eg both hatchbacks (Snoopy1)
yep aftermarket one.
thanks for the info.
civicHatch1
Jun 6, 2017 06:45 AM
punkracer
Mar 5, 2008 04:22 PM
alexb16hb
Apr 30, 2006 12:49 AM
Ej sick
Nov 12, 2005 05:36 PM
zerovandez
Feb 25, 2004 09:22 PM
