whats the difference....
Old May 15, 2003 | 08:55 AM
03Si's Avatar
Default whats the difference....
between the K20 motor in the Si and the RSX-S ??
Old May 15, 2003 | 10:25 AM
fireant's Avatar
Default Re: whats the difference.... (03Si)
For the most part the difference is in the intake manifolds, and the heads, where the RSX's iv-tec is tuned differently and affects exhaust as well as intake timings, while the civic is mainly focused in intake, low-end-torque and on ultra-low emissions at idle.
The ECUs are different, obviously, to handle these things.
The RSX-S also has a counter-weighted engine, while the CivicSi has a balanced engine, but the main blocks are virtually the same except for stronger internals in the RSX-s to handle those higer RPMs.
Other differences include the transmissions, and the Civic has electric power steering instead of traditional belt-driven, like the RSX has.
That's all I can think of right now...
Old May 15, 2003 | 10:49 AM
Josh02Si's Avatar
Default Re: whats the difference.... (hatch2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch2k &raquo;</TD></TR><TR><TD CLASS="quote">For the most part the difference is in the intake manifolds, and the heads, where the RSX's iv-tec is tuned differently and affects exhaust as well as intake timings, while the civic is mainly focused in intake, low-end-torque and on ultra-low emissions at idle.
Alot of this post has good information but however the Type S (k20a2) and the Si motor (k20a3) DO share the same type of intake manifold. You were right about the different stages of i-vtec though. The k20a3 acts as a 12 valve motor until around 2500 then it kicks up to 16 valve and only has vtec on the intake side. The k20a2 (type S) however has vtec on intake and exhaust. TO put it another way we got ripped off!!!! hahaha
Old May 15, 2003 | 11:18 AM
fireant's Avatar
Default Re: whats the difference.... (Josh02Si)
Its the Base RSX with a different kind of intake manifold, right?
Old May 18, 2003 | 07:55 AM
03Si's Avatar
alright.
so what's a balanced engine, and what's a weight-counter engine?
would it be possible to add vtech on the exhaust side?
Old May 19, 2003 | 02:56 PM
Boost Ambassador's Avatar
To be simple RSX DC5 is better.
EX. B18C better than B16A
xXxDelSoulxXx
Jan 5, 2008 09:52 PM
StuDizzle
Nov 21, 2005 08:41 PM
Top Ramen
Aug 20, 2005 08:07 PM
blackpearl169
Aug 3, 2004 08:49 PM
newskoolhatch
May 20, 2003 02:04 PM
