need obd0 - obd1 conversion hareness info
Alright , heres the scenario...... Im goign to be putting a Z6 head and intake in my 88 CRX, and using a P28 ECU. I need to know what harness i use, and what all wiring and resistor stuff i need? HWta about the injector box in my car??
Also does anyone make the harness for me??
THANKS
THANKS
88 CRX... is it DPFI or MPFI? If it's DPFI then you have to start off by doing the MPFI conversion. After that you need to do the OBD-0 to OBD-1 conversion. You can get a jumper harness to get the P28 to plug into your under dash harness or you can hack off the harness connector and solder on the OBD-1 connector (makes for a big wiring mess... have fun).
That is the basic answer to your question.
You can use the search function and figure out the specifics or you can just click here -
https://honda-tech.com/zerouser?cmd=CRXconversion
ITs an si , so im set that way , but i was informed that someone on this site made conversion harness's to solve what i need.
IF that person or anyone who has or knwos where to get them please let me know.
THANKS
THANKS
