Piston ?'s for a D16Y8 Turbo
Ok, well the junkyard turbo project for my car is heading on to the next step. I picked up some LS rods to be machined out, but I wanted to got an idea on what pistons might be good for my setup.
I know for NA everyone is fond of using the P29 pistons. But those produce way to much compression for a turbo motor.
So, keep the stock pistons from the y8, or are there any others that might work.
Keep in mind that I do not have the money right now for aftermarket pistons, I am looking for something from the d series family of engines that I can go to the junkyard and pull (and then go get new rings from the dealer).
Any ideas out there?
Not sure what you have in mind but i think turbopanda(?)(the guy in thailand) uses supra pistons in his turbo setup...I'm sure you read Spades write up on the d's but if not, there's a link in my sig.
yes...I read over on http://www.dseries.org that vx rods are quite big.....confirm this with mistabone on the board
