94-97 Accord cluster install help
Can anyone post a picture of how the dash cluster comes off a 1994 Accord EX ?? What I am looking for is possibly a scan of the shop manual with the parts separated or maybe an install picture you took while installing your cluster. Some pointers on how to remove/install the cluster would also be greatly appreciated. I am helping a friend replace his cluster and I would just like to see how it all comes apart. Thanks !!!
1. disconnect negative battery cable after you make sure you have your radio code
2. remove all the switches for sunroof, cruise, rear defroster, hazard by inserting a snall jewellers screwdriver into the slot at the botton and gently prying up
3. remove console by removing ashtray and screws behind it, cupholder and screws under it, radio, and take colsole off
4. remove all 6 screws for instrument cluster bezel 2 at the top, 1 at left vent opening, 3 where the console was.
5. using alittle pressure pull bezel out and unplug electrical connectors
6. remove screws holding instrument cluster in place and remove cluster and unplug electrical connector.
hope I did not miss anything
this pic might help also
i hope the picture pops up if not try the link http://community.webshots.com/...eaEAX
Im Selling an accord cluster exact same as this one in good condtion 94-97 Will work on and ex or lx. Selling for 60 shipping included Witch is cheapest as they go. Contact me for more info
Google specificly what you want and you'll find a perfect step by step video that shows everything from removal to complete disassembly and you can pause anytime to work at your speed. I've never done anything like this and found it quite simple!
WhiteOnRice
Aug 12, 2006 12:04 PM
