Off of what motors can I get the Z6 vtec connectors for rigging up vtec???
Old May 15, 2003 | 03:23 AM
smithbling's Avatar
Default Off of what motors can I get the Z6 vtec connectors for rigging up vtec???
I am in need of wiring the vtec for a mini-me swap I require the vtec oil pressure and vtec signal connectors as they did not come with the head I bought.
Can I only use the ones from a Z6 head? OR will Y8 connectors work also?
Old May 15, 2003 | 04:36 AM
egchan's Avatar
Default Re: Off of what motors can I get the Z6 vtec connectors for rigging up vtec??? (smithbling)
yeah, if you can find then off of a y8 it will work. you might even try to see if you can get it off of a b series if available. the connectors should still be the same. if not, just cut off the connector and use male-female connectors.
89ED
13
Oct 24, 2013 09:53 AM
Fezzie
May 10, 2006 11:59 AM
specificcivic
Dec 27, 2003 11:56 PM
slowman
Jul 16, 2002 09:49 PM
