WTB: Sleeved LS Block
Old May 14, 2003 | 11:45 PM
EgSick's Avatar
Default WTB: Sleeved LS Block
im looking for a Sleeved Ls Block
prefer built
but really need it Sleeved
thanks
Old May 15, 2003 | 09:13 AM
ExospeedAMcrx's Avatar
Default Re: WTB: Sleeved LS Block (EgSick)
we can do the sleeving for you. nothing already sleeved right now, but we have LS cores available that we can sleeve.
Old May 15, 2003 | 09:24 AM
__37__'s Avatar
Default Re: WTB: Sleeved LS Block (exospeedAMcrx)
same here. looking for a sleeved ls block. how much for a sleeved ls block, and how much for you to sleeve my block when i send it? i want to be able to run 84 mm pistons afterwards as well. thanks
Old May 15, 2003 | 09:29 AM
Default Re: WTB: Sleeved LS Block (__37__)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by __37__ &raquo;</TD></TR><TR><TD CLASS="quote">same here. looking for a sleeved ls block. how much for a sleeved ls block, and how much for you to sleeve my block when i send it? i want to be able to run 84 mm pistons afterwards as well. thanks</TD></TR></TABLE>
Sleeving is $880 with bore, hone, hot tank, deck, etc. if you provide the piston at the same time or purchase it from us, we can bore it to the exact specs of the pistons you give us. no extra charge on overbore size. once you receive the block back, it should be ready to assemble... No Other Machining Required.
habib
Mar 6, 2010 09:46 AM
civictypenos
Sep 6, 2003 10:35 PM
USDMMARK
Feb 9, 2003 01:58 AM
